Wet 911 SC Motor
When it rains and my car is parked at work all day, the motor gets wet and runs like crap. I noticed its wet up high under the grille on the deckid. I opened it up before I left work this evening and there was water on top of the air box, a/c compressor, and coil. Is there a way to fix this or do I need to put some kind of tarp over the deckild when it rains?
Old 02-18-2005, 10:41 PM
randywebb's Avatar
something is wrong - the car should be just fine with rain going thru the decklid. check your intake system...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 02-18-2005, 10:49 PM
Welcome to the world of Beru.
Cheers,
Joe
Old 02-18-2005, 11:44 PM
GettinHeadStuds's Avatar
Re: Wet 911 SC Motor
How do your ignition wires look?
83 SC (gone) / 72 T (gone)
Old 02-19-2005, 12:17 AM
durn for'ner
livi's Avatar
As Mr SuperHarp himself used to sing :
"When it rains, it pours"
Markus
Carrera 85
Markus
Resident Fluffer
Carrera '85
Old 02-19-2005, 04:03 AM
Driver Ed's Avatar
If a little water causes it to run poorly, I'd change the plug wires, distributor cap and rotor. You might also look at all of your vacuum lines carefully, but that's a distant second place suspect in my opinion.
Old 02-19-2005, 04:26 AM
I had the same problem and fixed it with new plug wires. Let it rain!
1981 911 SC 7 & 9 Fuchs, monoballs, 22/27 t-bars, 19/22 swaybars, M&K dual in/ dual out
Old 02-19-2005, 07:21 AM
I would rather be driving
jpnovak's Avatar
Clean all the connections to the coil. Replace you ignition wires and use some silicone dielectric grease on all the connections.
Old 02-19-2005, 07:23 AM
You might just want to eliminate the wet Beru fiasco entirely with a set of Clewett Engineering High Performance Ignition Wires - RED, 911 (1970-83), 911 Turbo (1984-89) [Photo] [Photo] http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_igniti_pg2.htm#item7
I doubt these wires as designed even need any dielectric silicone grease to operate in the rain.
Cheers,
Joe
Old 02-19-2005, 08:51 AM
