Need help diagnosing electrical gremlin
Actually, I've got a few electrical gremlins. I figure I may need to start pulling my hair out with a meter and wiring diagram and pulling the interior apart looking for bad grounds and the like, but I figured I'd bounce this stuff off of all of you first:
The big problem is, the turn signals, flashers, and fresh air blower all stopped working at once. There are no fuses blown and I've already tried replacing the flasher. The flasher light is not illuminated and, when I turn the flasher switch on, it lights steady instead of flashing.
Other gremlins:
The rear defroster doesn't work. Fuse is fine.
The interior lights work in reverse. In the doorswitch controlled position, opening the door turns them out and closing the door turns them on.
Anyone have any great insights on where to start looking for problems?
Thanks,
Phil
89 930 Slate Grey/Black
K27 B+B 1 Bar
shaved gutters
backdated to opening vent windows
Old 02-09-2005, 06:40 AM
bigchillcar's Avatar
phil,
are these problems with a car that you just bought or did all of these just suddenly happen? if so, has any recent work been done to the car that could be responsible? the rear defogger also has a relay in the back in addition to the fuse..if it's bad it won't work. so, you tried replacing the flasher relay with a new, correct one and it didn't resolve it?
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 02-09-2005, 07:51 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
I second Ryan! Very good advice.
Also check that a wiring harness did not get compromised, but '89 is a young car.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 02-09-2005, 07:58 AM
The light switches and the rear defroster were independent of any work. It just started happening, although the car sat for a long time before I bought it. It had 24k miles at the time.
The turn signal problem came about while I had the center console out before I installed an older style short console, so I had been thinking about starting there. I was wondering if anyone knew of a ground/wire that is a common problem in the center console.
Phil
K27 B+B 1 Bar
shaved gutters
Old 02-09-2005, 08:24 AM
a911's Avatar
I had all sorts of electrical gremlins, until i discover that i didnt tighten + pole on batery. Half the car had electricity half didnt and so on...
"88" carrera
"02" tt roadster (wife) sold
"04" jaguar x-type
"04" kawasaki zx10r
"05" yamaha mayesty
"05" A3 sportback
Old 02-09-2005, 08:28 AM
the flasher relay is seated properly in the socket? the symptoms were the same with both the old and new relay?
ryan
Old 02-09-2005, 08:30 AM
Interesting. I'll clean and check the battery terminals.
Unfortunately, yes, the symptoms didn't change when I changed flashers, and the flasher was seated quite well.
Phil
K27 B+B 1 Bar
shaved gutters
Old 02-09-2005, 08:36 AM
Phil,
Sounds like a bad common ground. Not sure about your year, but there's usually a common ground point for many circuits under the dash. Porsche ground wires are usually brown. It might be loose or dirty or both.
A wiring diagram can verify a common ground serves these circuits that don't work.
Hope this helps,
Sherwood
Old 02-09-2005, 10:29 AM
That could be. I was poking around behind the dash. I'll dig around behind the dash and check the diagram.
Phil
K27 B+B 1 Bar
shaved gutters
Old 02-09-2005, 10:44 AM
JOT MON ABBR OTH
Phil,
A nasty little four footed rodent could have gotten in and done damage as well. Them and roaches like to eat the insulation off wires. I've had this happen before.
Old 02-09-2005, 11:15 AM
I don't get the sense or smell that critters are the issue here, but I appreciate the help. I also like your Lazarus Long quotes.
Phil
K27 B+B 1 Bar
shaved gutters
Old 02-09-2005, 11:54 AM
911mot's Avatar
For the turn signals check the hazard (flasher??) switch connections at the back. The interior lamp problem sounds like the bulb holder could be wired up wrongly. The fresh air motors are known to fail. Check for live feed at the multiplug to eliminate switch
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 02-09-2005, 12:17 PM
Tried the hazard switch connectors. The interior lights used to work properly, then they spontaneously changed. Fresh air blower and turn signals failed simultaneously.
Thanks for the suggestions.
Phil
K27 B+B 1 Bar
shaved gutters
Old 02-09-2005, 12:49 PM
i seem to recall a ground wire underneath the dash that when disconnected, the fan blower didn't work..don't recall what other circuits were affected, but if you worked on your dash as you say, that would be my suspicion.
ryan
Old 02-09-2005, 01:00 PM
Awesome stuff! You guys might have saved me hours and hours of digging around. I'll look into it.
Phil
K27 B+B 1 Bar
shaved gutters
Old 02-09-2005, 01:05 PM
