RSM-M491's Avatar
Question Checking Oil....Is this normal?
After driving the car for about an hour today (the rain finally stopped here!). I got home and decided I better check the oil level. With the car running ofcourse, I open the Yellow cap, and when I did, I noticed the car started to idle a little more rough/lower?! Oil level was perfect, but should I be concerned or is this normal? I was thinking maybe it was sucking air in through the opening, and some how causing this?
Thanks!
Rod
1989 911 Targa M491
1980 Triumph TR8 (sold)
2006 BMW M3 (Interlagos Blue)
Old 04-28-2011, 01:48 PM
Vin-barrett's Avatar
it is normal, no worries
-Vinny
1983 911SC
Old 04-28-2011, 01:51 PM
RETIRED
Joe Bob's Avatar
You have intoduced a vacuum leak by opening the oil cover......normal.
2012 ML350 3.0 Turbo Diesel
RSM-M491's Avatar
Shew...
Thanks guys!
Rod
1989 911 Targa M491
Old 04-28-2011, 01:55 PM
Where do you live?
Old 04-28-2011, 01:57 PM
RSM-M491's Avatar
Louisville, KY
1989 911 Targa M491
Old 04-28-2011, 02:23 PM
On Tour
MMiller's Avatar
My car won't stay running with the cap removed. If I take a reading while it's quitting running or right after it's quit will that reading be close enough?
Mike
Old 04-28-2011, 02:46 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Mike
It appears you have a vacuum leak somewhere else or your idle is too low. What year is your baby?
'85 Carrera Targa
PCA/POC
Old 04-28-2011, 03:24 PM
you need the restrictor that's supposed to be in the top breather hose at the filler neck. then it won't die.
206 637 4071
Old 04-28-2011, 03:58 PM
On Tour
MMiller's Avatar
It's a 1988 and it idles around 900 rpm
can I buy this restrictor here at Pelican?
Thanks for the help
Mike
Old 04-28-2011, 08:32 PM
