CV joint sizing
Hi, I'm trying to match up 944 driveshafts to a 1968 901 gearbox.
The output flanges on the 901 measure around a 76 pcd x 6 bolts and up to 90mm outer dia.
Does anyone have one of these joints that could measure the diameter and number of splines on the drive shaft, as I wondering if the 911 cv will fit on the 944 driveshafts I have.
If this is not an option, I will have to change the output flanges on the gearbox to match the 944 CV's which are 100mm dia and 86 pcd x 6 bolts. Does anyone know what year/model output flanges I would need?
Old 02-11-2005, 04:54 AM
Nine9six's Avatar
Why not post this question in the 944 tech forum? You may have better results...
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 02-11-2005, 07:51 AM
Thanks, I'll give that a try
Old 02-11-2005, 08:13 AM
