-   -   DashTop™ dash "caps" are not bad! (http://forums.pelicanparts.com/porsche-911-technical-forum/205922-dashtop-dash-caps-not-bad.html)
MikeSid 03-09-2005 02:00 PM
"competent reupholstry" probably wouldn't be me doing it in my garage. But I think I may give this a shot.
Wrecked944 03-09-2005 02:30 PM
Dave, that is supreme. Thanks for sharing the pics and info. Don't be surprised if the day comes soon when you can spot a Pelican car by the ultrasuede on the dash cap. :D
MikeSid 03-09-2005 02:42 PM
Yellowbird RS 03-09-2005 06:10 PM
update on my hairliner
http://forums.pelicanparts.com/uploa...1110420553.jpg
http://forums.pelicanparts.com/uploa...1110420569.jpg
tomorow the dash & door arm rest ;)
doozer 03-09-2005 06:25 PM
So when you were done were you tempted to lay on your back in your seat and walk barefoot on your headliner - I would have been :D
That looks GREAT!
smestas 03-09-2005 09:11 PM
Wow! Headliners also. Looks awesome YellowBird.
We need to move these posts and make a "ultrasuede" thread.
}{arlequin 03-10-2005 12:51 AM
Maybe just a general "pimpin' my ride" thread :D
yello-bird, that looks great. Makes my dash job look like a spark plug job compared to a 915 rebuild ;)
Deschodt 03-10-2005 06:34 AM
Pimpin' ? The 997 has an alcantara headliner ;-) And it's the car's best feature too ! I am all for this ! Did you make the headliner by stitching pieces together ? Template ?
This is all very cool. Maybe I should fix my temps gauge first but I like this thread !
Yellowbird RS 03-14-2005 01:56 PM
an up-date
http://forums.pelicanparts.com/uploa...1110837029.jpg
http://forums.pelicanparts.com/uploa...1110837069.jpg
http://forums.pelicanparts.com/uploa...1110837107.jpg
http://forums.pelicanparts.com/uploa...1110837205.jpg
http://forums.pelicanparts.com/uploa...1110837226.jpg
http://forums.pelicanparts.com/uploa...1110837271.jpg
http://forums.pelicanparts.com/uploa...1110837345.jpg http://forums.pelicanparts.com/uploa...1110837376.jpg
}{arlequin 03-14-2005 02:00 PM
Wow, color-coded stitiching??? Now that's stylin' :D
Looks great. Did you do it yourself? Nice job! Very even stitiching. Guess that was a way to go for me too, but after I finished re-covering my seats I quickly returned the sewing machine back to the store :D
scottb 03-14-2005 02:03 PM
I'm impressed with the workmanship!
Let me ask the collective, though. Is the contrast between the vinyl on the dash and the ultrasuede too stark? Like them or not, the Dash Cap sort of blends in with the factory dash. Once upholstered with ultrasuede, the contrast is obvious.
Thoughts?
}{arlequin 03-14-2005 02:11 PM
It's a bit darker under the dash, so the un-upholstered part isn't as glaring, and besides, my dash top, and every one elses, was smooth (leather I think... maybe vinyl) while my dash panel is basketweave. I don't think anyone ever thought that they don't match even though the texture is different.
I haven't gotten around to it but I will post some pics later. In my opinion, the difference "disappears" and isn't noticeable.
Biff 04-13-2005 05:33 PM
Could this whole procedure be done with a good quality full grain leather, it might look better than original that way? Biff
techweenie 04-13-2005 05:47 PM
I've seen recovers done with the vinyl that has the *exact* grain cast into the factory dash. So it's definitely out there.
As a veteran of several 'dash top' coverup installs, I have to warn that they will warp badly over time. And if you use the silicone adhesive inconsistently, the shell will expand where it's *not* stuck down, making the warping potentially ugly. but at 1/10th the cost of a new dash (uninstalled) maybe replacing the dash cap can be considered maintenance.
Biff 04-13-2005 06:47 PM
I re-roofed a flat rubber roof section of my home last fall and used some really strong industrial contact adhesive. If that stuff can take direct sun year after year for 20-30 years I would think it could hold down a piece of vinyl or leather for a while. What do you think? Biff
techweenie 04-13-2005 07:22 PM
Biff, use a lot of it, uniformly under the entire area, and I bet it'll essentially be permanent.
Deschodt 04-14-2005 06:32 AM
I've gotten a dash top following this post and I gotta say the fit is impressive ! In seconds my car went to multiple cracks dash to smooth ! it's not the same material, it's a toupee alright, but I kinda like it ! The only thing - not reported above - is the fit is so-so where the air vents are. You have to remove the plastic air vent covers fo ra good fit and then you have those ugly metal slats visible... But overall, for $80, I'd recommend one !
}{arlequin 06-09-2005 11:36 PM
"appearance update"
http://forums.pelicanparts.com/uploa...1118384902.jpg
http://forums.pelicanparts.com/uploa...1118385000.jpg
http://forums.pelicanparts.com/uploa...1118385192.jpg
89turbocabmike 06-09-2005 11:57 PM
Looks like it's holding up well Dave:)
smestas 06-10-2005 12:39 AM
MMMMMMMMMMMMMmmmmmmmmmmmm..............
Me likes that dash alot }{arlequin!!
