1974 911 Aluminum Brake Caliper
Has anyone out there had any luck using a Helicoil to repair the stripped out brake line banjo bolt treads on a 1974 911s aluminum brake caliper?
1974 911s Aluminum Brake Caliper
Correction : It is a 1974 not 1994 ( Typo)
1994 or 1974?
I would be more inlined to use a timecert than a heilicoil since they're much stronger and the pressures in the brake system is pretty substantial
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Thanks Tim for the quick response. I 'm not familiar with a timecert. Would you explain in furthur detail and do you know of anyone doing this repair successfully?
Thanks, Tim |
and???????
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Hi
That is just a correction to my previous post. |
You can "edit" your post by clicking on the
Administrator
I merged the two threads together.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
What would we do without you?
