Broken Clutch
My clutch seemed to start losing adjustment a week ago. On Friday it went away all together meaning it will not disengage. I adjusted per spec and the lever travel underneath seems to be fine but there is no disengagement whatsoever. If I fully depress the clutch pedal with the engine cranked there is a high pitched squeal. I am quite sure an engine drop is required to further diagnose but does anyone have suggestions before I go looking further?
Thanks Kevin
Kevin '79 Coupe |
Unregistered
Could be several things, the one that jumps out is the problem with OEM 911SC clutch discs.
They came with rubber centers which work very well, for a while. Eventually the rubber starts to break and chunks get caust in the works, preventing the clutch from disengaging. If it's the original clutch this may be a possibility. Other things to check are throwout bearing, clutch fork, clutch cable, roll pin in the pedal assembly, in other words, all the things that transmit the force from your foot to the pressure plate. How does it feel when you depress the pedal, the same as before? |
The clutch was replaced per PO documents. The effort to depress the clutch is much less than before. I did have this done while I was under the car and the lever there is actuated by the cable so I am pretty confident the cable is not the issue. From reading posts found via search it appears the clutch fork or other internal devices are likely suspects. Just didn't want to miss something obvious.
Thanks Kevin
Kevin '79 Coupe |
Unregistered
I agree, prolly the clutch throwout mechanism. There's an inspection window in the tranny belhousing to look through but I've never been able to see anything through it with a mirror and flashlight, I pull the starter and look through there to align everything when bolting in the engine.
Pulling the start is a PITA but easier than dropping the engine, if you did pull the starter at least you could see what's happening inside there. Youll prolly still end up pulling the engine so chances are you won't save any work. Your call. |
I do believe this is the problem. I pulled the engine tonight and it was pretty obvious.
Kevin '79 Coupe |
JOT MON ABBR OTH
Well, I was going to tell you that the clutch cable could have been stretched, but looks like you found a a different source. Been there! Easy fix! Now, while your in there...
David '83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)'15 F250 Gas (Her Baby) '95 993 (sold )I don't take scalps. I'm civilized like white man now, I shoot man in back. |
Just be sure you align the new fork into the t/o bearing on reinstall, or you'll have the exact same feeling first time you push the pedal in.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
David, I do have a long while I'm in there list. This just forced my hand which is a good thing. My car now has 170.000 miles so it has all of the normal issues. I am sure I will be here with questions and comments as I go as well as photos asking the many experts here for opinions and comments.
Kevin
Kevin '79 Coupe |
I had the same problem in my carrera, except the throwout arm was just cracked. It would work fine sometimes, chatter sometimes, wouldn't dis-engage sometimes, get stuck in gear sometimes,....kept checking everything. Sometimes when it just breaks, it's easier to fix. Intermittent sometimes it works, sometimes it doesn't, drives me crazy!
Randy 73.5 911 T 97' C2S 06' C2S |
Now that you are in there:
You mentioned that the clutch was replaced by the PO but it may be that only the certain parts were replaced. Check the records you have from the PO and look to see what was done. When I replaced my clutch I had the following done: Pressure plate Disc Throwout bearing Release bearing fork !!!! Pilot bearing Guide tube Main shaft seal Rear main seal 9 pressure plate bolts 9 Flywheel bolts Clutch cable Clevis fork and pin re-surface flywheel. Before you button up your car check these items or you may be back in there for something else. Thanks
The Fox Carrera Last edited by kqw; 02-17-2005 at 08:25 AM.. |
make sure you lube the mainshaft splines and around the guide tube. inspect the guide tube for wear also. they're dry as a bone, not good.
The guide tube and throw out bearing seemed to take some abuse, I assume in the time the arm was going away. I plan to at the very least replace these items, rebuild the fork assembly and closely inspect the clutch, pressure plate, and flywheel. The clutch was performing normally it seemed until this occured. John, the smaller helper spring on the small clutch lever is missing. Any chance this could have caused the damage. Doesn't matter just trying to put a finger on why things happen. I do appreciate all of the advise and will certainly check anything you guys can think of.
Thanks Again, Kevin
Kevin '79 Coupe |
Just a note: if you remove the pressure plate and flywheel bolts remember these are stretch bolts and should not be re-used....
The Fox Carrera |
I have a used fork, if you need one.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
The Fox Carrera |
right - someone did a search and found PAGs TSB on this - the bolts were changed at some point in the late 1970's - no change needed on an SC.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Senior Member
I know of no one who reuses flywheel bolts. I won't. Pressure plate bolts, yes. Flywheel bolts, no.
Be sure you replace your oil thermostat o-ring while the engine is out.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I have re-used fly wheel bolts on my SC and Carrera (with a little red locite) and never a problem. I put 125K miles on the Carrera, it never came loose.
