rexav8r's Avatar
More help - half shaft removal
Alright.
I've got all (8) the flange bolts off of both ends of the passenger side half shaft, which appears to be a Lobro.
I can't get either end (tranny or wheel) off.
Where am I "supposed" to be hitting it with the soft hammer (or hammer and wood), right against the CV joint???
How do you get this MUTHA off ??? !!!
I gave it a good BI#@H slappin' and all it did was hack up and drop a glop-O-grease/grime on my forehead!
Richard W.
Red '70 E, 2.2
White (w/ Red & Blue), '82SC, "Frankenstein" -a bit tweeked
Old 02-14-2005, 08:11 PM
pjv911's Avatar
Send a message via AIM to pjv911
Use a ball peen and hit it directly outside the dowel pins . Dont resort to prying , there is a gasket surface there. Dont be afraid to use force . Just be accurate .
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 02-14-2005, 08:22 PM
buster73's Avatar
There are gaskets on both end of the driveshaft, that almost glue the CV's in place. Try prying carefully between the CV and the hub resp. the diff flange. Don't pry at the wrong end of the CV flanges (close to the bolts) but on the outer end of the CV flanges (approx. 1.5 inch from the bolts). The CV's are also positioned by two steel pins on each end that have to come out approx. 1/2 inch before you can remove the shafts.
Regards,
Guenter
73.5 911T, mod
Old 02-14-2005, 08:27 PM
rexav8r's Avatar
Thanks Guys !!
Half shafts are out!
I used the pry method, but had to use a tiny screwdriver and hammer to carefully chisel through the gasket. Then popped a larger screwdriver in to do the real pry part.
You can't just whack this model from the side because of the roll pins.
The only (obvious) problem was that I hadn't done it before.
With all the GUNK on there I wasn't sure where the gasket was and didn't want to mar-up the wrong part.
I'll write up a little tech article tomorrow with some photos and send it to Wayne. Maybe he'll add it to the tech article already listed. I couldn't find any good pictures with arrows anywhere...
Richard W.
Red '70 E, 2.2
Old 02-14-2005, 10:01 PM
pjv911's Avatar
A tech article that reccommends smashing a screwdriver in between the gasket surface . Thats priceless .
Kurt Williams
Old 02-15-2005, 04:20 AM
rexav8r's Avatar
Kurt:
"That's Priceless"
I sure Wayne can put a price on it..
Richard W.
Red '70 E, 2.2
Old 02-15-2005, 05:21 AM
I use a wedge made from a plastic tent peg in lieu of a screwdriver. Tent pegs cost 50 cents each, their plastic is tough and will not mar the CV joint surfaces.
Old 02-15-2005, 05:46 AM
Irrationally exuberant
ChrisBennet's Avatar
Brilliant!
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-15-2005, 07:43 AM
buster73's Avatar
The gaskets only seal grease, so it is not too critical. You really have to mess the surface up to do any significant damage. With a little bit of care it's no problem. Worked fine for me for many years. In Wayne's 101 book he also recommends to "gently pry".
Regards,
Guenter
73.5 911T, mod
Old 02-16-2005, 08:04 PM
