Send a message via AIM to hahnmgh63
964 Engine vacuum hookup question
For those of you with a 964 I'm installing in a '74 911 I am trying to figure out where the hose that connects to this fitting on the manifold goes? Do I need it? Please see picture. By the way, anyone have pictures of a single alternator pulley intallation? Thanks, MGH
hahnmgh@earthlink.net
Old 02-16-2005, 11:39 AM
Silly me in a hurry
Sorry, I meant to put a arrow pointing to it. It is the shiny silver fitting just below and in front of the rubber 'Y' elbow. Good 1/2" in diameter. this is on the right rear of the engine looking forward. Thanks, MGH
Old 02-16-2005, 11:41 AM
Bill Verburg's Avatar
I've no idea what the silver thing is
single pulley
This is what the conversion piece looks like
Though you probably don't want to change the lower pulley out.
Bill Verburg
Old 02-16-2005, 01:49 PM
tholyoak's Avatar
Not needed, just block off or you will have a massive vacuum leak
Todd
1989 911 Targa
Old 02-16-2005, 07:01 PM
Thanks everyone. I'm still wondering about the lower pulley when going singe?
Old 02-16-2005, 07:06 PM
tholyoak's Avatar
Listen to Bill, you don't want to swap the lower pulley on a 964 engine. I believe Bill has a nice photo of a 2 piece crank made this way.
Todd
1989 911 Targa
Old 02-16-2005, 07:09 PM
You could change the lower pulley but then the crank will be more vulnerable, yhe 964 relly does want the harmonic balancer that is part of the pulley. here is what most of the factory RS did
Bill Verburg
Old 02-16-2005, 07:37 PM
Senior Member
john_colasante's Avatar
Bill, what you have shown in the upper photo is the 993 single pulley. It will not fit a 964 because the 964 used the tapered crankshaft snout. I'm sure you know this but i may not be clear here.
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 02-17-2005, 08:34 AM
Yeah I know, that's my car.
Yours is on of the few 964RS tht I have seen w/ the single lower pulley
John's 964RS
Even most of the 993Cups came w/ the triple lower pulley. Though they didn't nmeed it for anything.
Bill Verburg
Old 02-17-2005, 12:36 PM
Thanks everyone for the help. I see John's RS did delete 1 of the 3 bottom pulleys. I will try to come up with something. I have been waiting a long time to get this engine in the car although I still have to get busy on installing the 964 gauges before I can even start things up. MGH
Old 02-17-2005, 05:54 PM
