bagpiper47's Avatar
Fuel line replacement
When I change the accumulator tommorrow should I change out the fuel lines as well at this time? Or should I only concern myself if I damage one? (Hope not). If I need to change it might have to wait till next week as I dont think Sterling Colorado would have a handy set of fuel lines laying around. Dont know if NAPA stocks them. 2 hour drive to Denver. Wonder if anyone would have a set at the Swap Meet on Sunday.
Old 02-19-2005, 02:19 PM
Why? Are they leaking?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-19-2005, 02:29 PM
IROC's Avatar
Don't fix it if it ain't broke, I always say. If your existing lines look OK and they're not leaking, etc., then I would save that job for another day.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 02-19-2005, 03:08 PM
bagpiper47's Avatar
Thanks. they look fine. Engine is cooling overnite and will start wrenching tommorrow!
Old 02-19-2005, 07:02 PM
ASD ASD is offline
ASD's Avatar
I started to replace my leaking accumulator this weekend. Could not budge the fuel lines on the top. The bottom one was able to be lossened, but seemed like I would snap off the lines on top trying to unscrew the fitting.
Any tips for what seems to be an easy straightforward r&r?
Made me feel pretty frustrated.
Hard to hold the unit steady while turning the lines.
1999 Carrera2 tip arena red
2000 Boxster S tip...arena red ....black
1981 911sc targa...grey mkt.import...Rosewood
1978 911SC, guards red sunroof delete .much missed
73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead.
Old 02-20-2005, 05:56 AM
bagpiper47's Avatar
My accumulator is in and it started right up!! I used 2 wrenches to loosen the nuts. There is a place to put a wrench on the very bottom and then crank both at the same time. Only filled 1 rag with gas before I figured I would take the bottom one out last and put a finger over it and carry it away to a fuel dumping area.
My first project was a success!! Took me about an hour.
So between the Fuel Accunulator and a fog light bulb I paid for Waynes book, the accumulator and the bulb. Would have cost me $120+ in labor plus gas for 260 miles ($40) so everything was free!! Now if I can just convince my wife.
Thanks all
Old 02-20-2005, 08:48 AM
bagpiper47's Avatar
You can also take out the accumulator and fuel filter at the same time and take the lines off at the workbench. Mine had no problem coming off.
Old 02-20-2005, 08:53 AM
David's Avatar
bagpiper47, you don't say what year your car is, but assuming it's 20 years old I'd replace any rubber fuel line I take off if possible. There are too many engine fires with these older cars to take the chance. JMHO.
Old 02-20-2005, 09:16 AM
bagpiper47's Avatar
Cool
This was my first car work since 1989 when I gave it up after shredding an oil filter and paying someone to fix my damage.
Perhaps this summer I will change the fuel lines along with other projects that may need attention. AS for now I am celebrating the Accumulator replacement and off for a drive to get it warm.
81 SC 87,000 original, new clutch, airbox with pop valve, Cam tower lines (Professionally installed), Accumulator done with love.
Old 02-20-2005, 09:28 AM
