In middle of Clutch Replacement: Here are a few Pics....
I started my clutch replacement today:
I made a flywheel lock with a piece of metal. I then removed all of the 6MM Hex bolts that hold the pressure plate and clutch in place. I then carefully removed all 6 flywheel bolts without a problem. I was scared @$%@$ that I was going to strip something. It was unclear if the flywheel seal was leaking but I decided to remove it. The tranmission was definitely dumping goo all over this area.... Here is a pic of what I found... And here is what my engine now looks like after I have done a bunch of work... I do actually have 2 questions: 1) Is there any trick to removing the old pilot bearing from the flywheel? And is there any trick to installing the new one? 2) How hard is it to re-assmeble the new throwout bearing on the pressure plate? Other than that the clutch job looks very straightforward. 3) Anything else I should know replacing the clutch? Thanks. Ian |
to remove the pilot bearing - fill hole with grease - insert dowling or clutch alignment tool in hole - tap dowling with hammer.
cut a groove in pilot tube to let drips go down away from flywheel - Grady Clay's idea
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Do your homework before replaceing the flywheel seal. Make sure you have the correct one and the method of installation, Its a real ***** to drop the engine a second time.
So what is the correct flywheel seal part for a 72 T?
And what is the best way to install for years of leak free service?
Thanks. ian |
Feel the surface to be absolutely sure it is nice and smooth and flat.
Tap the seal in square...
I say your flywheel seal was leaking!
use a slide hammer to remove the pilot bearing.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
