-   -   Botched shifter coupler bushing replacement (http://forums.pelicanparts.com/porsche-911-technical-forum/207288-botched-shifter-coupler-bushing-replacement.html)
88 Club Sport 02-19-2005 02:07 PM
I was trying to remove the pin.... the pic says it all. I was surprised the coupler failed the way it did as I was not applying much pressure.
PP wants $90 for a new one, so much for a cheap busing replacement.
http://forums.pelicanparts.com/uploa...1108850651.jpg
jester911 02-19-2005 02:12 PM
Geez, I did not realize the price had went up so much the couplers. I bought a new one here about 2 years ago and I pretty sure it was 30 something bucks.
Sorry for your misfortune.:(
scottb 02-19-2005 02:18 PM
If it's any comfort, I did the exact same thing when I went to change my coupler bushings. ***** happens.
Jerome Ryals 02-19-2005 03:02 PM
I think I have a couple of the couplers if you are interested let me know. J R
PorscheGuy79 02-19-2005 03:08 PM
I read Waynes book and he says specifically not to do it yourself and that the couplers break easily . When I changed mine out I spent the 10 bucks for the machine shop to push it out and put the new one in. Seems like a worthy ten bucks, hopefully someone will read this and learn to aviod it themselves.
Hindsight is 20/20.
cgarr 02-19-2005 03:10 PM
I think you need to hold the part with the pin in it, and dont use a press, but to answer your question? you can weld these up just fine.
Craig
KobaltBlau 02-19-2005 03:25 PM
Oh rats!
88 Club Sport 02-19-2005 03:26 PM
Yep, I did read Waynes "be carefull, these break" caution but so many had done it, I thought If I went slow, I'd be ok. As you said, Hindsight is 20/20.
Thanks for the offer JR, I'll see if I can talk one of the Denver guys into welding first if not, I'll contact you.
Jared at Pelican Parts 02-19-2005 03:51 PM
JB Weld works on these too...
I used it once and it lasted for years
Jess 02-19-2005 04:10 PM
Craig
When I did the same thing a few years ago, I got one from Dave at Dart. I'm sure he'll have several at the Swap tomorrow.
Jess
vesnyder 02-19-2005 07:11 PM
Did the exact same thing! I replaced with the same but you may want to consider the coupler from Seine. If I broke mine again I would spring for the Siene option.
rattlsnak 02-19-2005 08:16 PM
Go with the WEVO...
Wayne 962 02-19-2005 09:33 PM
Hindsight is 20/20.
I'm the kind of guy that will try anything once. Then when it doesn't work for me, I recommend not doing it, as in this case.
The dollar has dropped a minimum of 30% since two years ago. Everything is way more expensive now, and still rising!
-Wayne
Oracle 02-19-2005 10:46 PM
Exactly the same happened to me when I used the press to push the pin, I'm pretty sure the 'T' section was a solid piece, so there was no pin to push., so basically it was disposable.
Maybe you had the same coupler as I did...
I got the replacement from a wreck and that one looked different, so maybe there are 2 kinds of coupler.
Bye
J
88 Club Sport 02-20-2005 12:29 PM
The timing of our local annual PCA swap meet was perfect....today. So, I picked up a used one for $20 from Dave at DART and figured I'd give another shot.
I used a large socket to support one side of the coupler so the pin could be pushed through and a small socket on the end of the pin to push it....then, slowly turned the vice. Getting the bushing back in was not easy but after a stint in the freezer and another socket, I was able to press the bushings in. I gave the pin a polish with 600 grit and then pressed it in with my vice.
Done !
scottb 02-20-2005 12:49 PM
So it was a $20 learning experience. Not bad!
N11Porsche 02-20-2005 01:31 PM
Not trying to be a kill-joy but maybe we should pm people if we are going to recommend another vender that competes against our host...
Jess 02-20-2005 01:48 PM
Bill
I certainly respect the fact that Wayne is in the parts business. I also respect that he provides us with this medium. I wouldn't tell anyone that a competitor has an identical part for a buck or two less and that's not what I did here.
We had a PCA swap meet this morning at a local used parts vendor and I pointed out to Craig that I had once found the same part he needed there. I am sensitive to the fact that Pelican Parts is a business (a company that I make purchases from) and I really don't feel like a crossed any ethical line here.
I welcome the opinion of others if I am wrong on this.
Wayne, I meant no offense here.
Jess
jester911 02-20-2005 01:51 PM
The key word here is "used" . There is usuallly no problem with used parts. It is new parts that are also offered from our host that pose a problem.
No biggie:D
