injection pump #'s
I have an injection pump on an anonymous engine and the # on it is
0408 128 010
maybe that 8 is a 6 but it doesnt matter, I believe, I think the last three is the key. anybody ever seen an 010 before?? its either a T or an E and its a 2.4
any help is always appreciated.
Nabil
Old 03-23-2005, 10:14 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
2.2 911E
Old 03-23-2005, 10:23 PM
unfortunate for me!!
but its good to know, nothing like a 2.2 pump on a 2.4
that may explain some of the popping and difficulty in tuning!!
thanks
Old 03-23-2005, 10:59 PM
jluetjen's Avatar
Do a search on MFI pumps. It's not clear that just having a 2.2 on a 2.4 would cause a lot of problems since the adjustment range covers that sort of change, especially at idle and part throttle. Keep in mind that it's not even 10% change in fuel volume being pumped. Are the the throttle shafts tight? If there is any play in them you most likely have air leaks which would be a more likely cause -- and completely non-pump related.
Do you have a copy of "Check - Measure - Adjust"? Have you gone through the adjustments exactly in the order shown?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-24-2005, 03:53 AM
John is right about the displacement difference not having a huge impact as long as the pump was readjusted for the increased displacement. I have used a 2.0 pump on a 2.2 and a 2.4 pump on a 2.7 with good results. However, because the pump is an"E" pump you should have "E" cams in the motor. Any other cams may make the pump untunable for all RPMs.
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 03-24-2005, 05:55 AM
actually the engine does have E cams in it! I went one click richer on the part throttle adjustment and it seems to have helped. I also printed a copy of Check Measure & Adjust. is the rev limiter on these in the rotor?? although this car 'seems' to have all E parts it seems to hit the rev limiter at 6500 instead of 7K.
thanks for all of your help fellas
Nabil
Old 03-24-2005, 05:26 PM
one last question for ya fellas, MFI related. the throttle doesn't shut all of the way 99% of the time. so I have this foolish 2500-3500 idle!! I have to go to the back of the car and pull the throttle shut with a gentle tug on the lever, or if I'm at a light I have to keep jabbing the gas hoping it closes... the springs look fin and I've cleaned them, I remove the linkage rods and cleaned and oiled them and I looked for the problem at the pedals but that seems fine too
any hints??
cars been in storage for many years and I'm trying to sort it by autocross season!!
p.s. what do out of adjustment valves sound like??
Old 03-24-2005, 06:50 PM
jluetjen's Avatar
any hints??
You never answered my question -- do you have "Check - Measure - Adjust"? Given your questions I assume not. You can download almost all of the MFI technical information that you'll ever need including CMA here. Once you've read the theory of operation the thing to do will be to work through the set-up procedure from beginning to end. In order.
tititititititititititititi
John
'69 911E
Old 03-25-2005, 03:50 AM
Great info on MFI ! I don't mean to hijack this thread, but I 'm a noob to 911's and MFI as well. I have a mystery motor in my 69' 911E. I have found locations (within this site) to determine almost every spec on the motor. The only exception is the MFI pump.
The number on my pump is:
0408 126 014
Any ideas, what pump this is?? There is also a second number on the pump: 3210880A
I'm now going to go back to reading about how great my MFI motor is It does run EXTREAMLY well and the throttle responce is amazing.
Old 03-25-2005, 07:01 AM
