info about my cams timing ?
Hello
I did this my cam timing like the Wayne book and the final result on the left is 4.41 mm and the right is 4.46 mm ZI on the crank. my intake valve overlap is 4.2-4.6 (4.3) page 207 . Do you this I am OK ? If it must be perfect on 4.3? Thanks for your help !
1960 356 BT-5 Aetna blue 1973 911 RS récréation 1960 VW panel Dove blue 1971 914 barn find ! Last edited by Raynald; 02-20-2005 at 04:18 PM.. |
Those numbers look very good to me.
Vary rarely have I managed to get it absolutely perfect for both sides. However what I try to do is get the max lift as close together as possible. This seems to help the motor run smoother. Thus if I have a choice of 4.3mm on one side and 4.4mm on the other, or the choice of 4.2mm on both sides, I would choose 4.2mm. Good luck with your cam timing. David Duffield |
