Rear spring plate bolts
Does anyone know where or how I can obtain new alignment bolts in the spring plates? The ones with off center oval heads to adjust camber and toe. If PP sells these, then please hold my hands and direct me in the right direction. If not, as I couldn't find them, does anyone have an idea? Should I just give a "parts house" a call on used ones?
Thanks for listening and any ideas.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Pelican can get anything the dealer sells. And, could you use used pieces from the salvage yard? Just a thought.
I think those bolts are spendy, so used ones might be smart - they can be replated.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Thanks, so worst case scenario I could just ask them to order them in for me. I'll talk to used parts houses also. Are the part numbers in the manual? If not does anyone know where to get the part number.
TIA
Here are the part numbers:
toe eccentric bolt: 901.333.133.00 camber eccentric bolt: 901.333.133.03 You can search Pelican's catalog by part number. Looks like the toe eccentric is superceded by the bolts for later models (901.333.133.05). Here are links to the results: http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&uid=default&description=90133313303&view_records=Click+to+View+Parts&re=on&mh=20 http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&mh=20&view_records=yes&uid=default&description=90133313305
John |
Nice job, and thanks John D. 2 years here and I still can't find what others can. It sure ain't for the lack of time on here
$71.91 !! Oh yeh - you want some nice used ones....
Guest
Posts: n/a
I had to get the washers and lock nut recently from the dealer.
lock nut =1.72 each washer =7.12 each |
