Make My Day
wowzer911's Avatar
Mechanical Tensioner Adjustment?
RECENTLY PERFORMED ENGINE SWAP. NEW ENGINE HAS MECHANICAL CHAIN TENSIONERS (MODIFIED SEALED TENSIONERS) I LIKE THE IDEA, BUT READ SOMEWHERE THESE NEED TO BE ADJUSTED AT REGULAR INTERVALS. HOW TIGHT SHOULD THE CHAINS BE? HOW DO I KNOW WHEN THEY NEED ADJUSTING???
74 911S Targa ROW
Building Designer/Business Owner
Old 02-21-2005, 02:12 PM
Hi:
Although you likely do not want to hear this, but I'd strongly recommend that you install the pressurized Carrera tensioner kit instead of the mechanical ones you have.
Those mechanical ones were a very poor solution to the early hydraulic ones that were prone to failure.
Fact is, these engines expand FAR more than most people understand and the mechanical tensioners cannot accomodate this expansion at all. I've see very high rates of chain and sprocket wear with those things and when the Intermediate shaft and its sprockets become worn, you must split the cases to replace it.
From experience, its FAR cheaper to purchase & install the Carrera Tensioner kit, then perform regular replacements of the chains, cam sprockets, idlers, and intermediate shaft spockets.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-21-2005, 03:46 PM
armandodiaz's Avatar
I second that. do a search and there's a post of how to prepare for a Carrera tensioner failure. This would be good to do while you are doing the upgrade.
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 02-21-2005, 05:53 PM
