Rear Tire wear?
My tires are worn out on the insides is there a way to adjust so the tires are more flat. I guess some one adjusted it this way so it will corner better but the tires are still good on the out side I have some wear bars showing now on the tires. What happens when the rubbers around the torsion bars are worn out. Does this cause the tires too wear on the inside?
Old 02-15-2005, 09:11 AM
This problem is with the rear tires.
IROC's Avatar
Tires wearing on the inside like you mention is due to excessive camber for the way you're using the car.
Most likely an alignment will solve the problem. I wouldn't suspect the bushings (as a result of the negative camber). They shouldn't be a factor.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 02-15-2005, 09:13 AM
So an alinement well bring this back tooo normal what is the normal chamber setting?
Old 02-15-2005, 03:44 PM
Formerly bb80sc
Vipergrün's Avatar
If you drive on the street, probably -.5 to -1.0 negative camber and 1/16 toe.....
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 02-15-2005, 03:48 PM
Can I reduce chamber myself with a smart chamber device with out having to have the car realined?
Old 02-19-2005, 05:19 PM
No
Old 02-21-2005, 10:52 AM
ttweed's Avatar
Originally posted by IROC
Tires wearing on the inside like you mention is due to excessive camber...
It can also be due to excessive toe-in. Either way, an alignment is the answer, and deformed bushings should be replaced.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 02-21-2005, 11:15 AM
How can I measure toe in?
Old 02-21-2005, 11:31 AM
Toe in can be measured by measuring the distance between the front edge of the rear wheels and the rear edge. Either way, you'll have to get an alignment done to fix the problem. You probably have excess camber, but you may also have too much toe. Your two options are to get an alignment or start driving much more aggressively which will help the tires wear much faster, but also more evenly if the problem is only due to camber. The only fix for excessive toe is to get an alignment.
Old 02-21-2005, 11:40 AM
For more info read this thread.
Toe Adjust Techniquest
Old 02-21-2005, 11:41 AM
If you are thinking about saving those tires or trying to get a bit more wear out of them, you will probably have to remove the tire from the wheel and switch them Left to Right, putting the unworn tread on the inside of the wheel.
Tony G
2000 Boxster S
Old 02-21-2005, 12:45 PM
Funny I mentioned doing this too a tire shop and they laughed at me. I will try another shop.
Old 02-21-2005, 01:18 PM
I used to do it once a season when I was using my street tires for DE events. It sure kept the wear even. Finally bought a second set of wheels and track tires.
Tony G
2000 Boxster S
Old 02-21-2005, 01:58 PM
I don't think it's recommended, but it's not uncommon.
You could always join a drift team. that would probably fix those tires.
Old 02-21-2005, 02:10 PM
Of course! How else are they going to rake you over the coals on a new set if you keep getting more out of your old ones ? Tell them to go pound sand.
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 02-21-2005, 05:42 PM
