dats da ones. less than $10 each.
Summer has been great! Lots of rain up here during Dec/early Jan, then a dry spell until last weekend. Temps were mid 30's (celcius) during most of the dry spell. I spent most of December in Cape Town area, where the weather was equally good. What open space? LeRoux |
993 studs are Dilivar steel studs.
Dilavar is a type of stainless steel, probably either a 300 series alloy derivitive or chromium/nickel alloy that is non-magnetic.
The 993 studs I installed were not stainless steel, they were carbon steel and are definately magnetic. Same as the oem upper studs. They were not dilavar. |
Absolutely, positively replace them. Use plain ol' steel ones. When you remove the old ones, use an oxy/acetylene torch to heat the area up along the edge of the spigot, about a half-minute to one minute, roughly. Then they will come out fine. Don't try this without heat. Propane will not come anywhere close to the heat you will need.
I used MAPP gas when I removed mine, not as hot as acetylene but much hotter than propane or butane.
Took a little longer (several minutes per stud) but the result was all good. If you don't have access to an oxy-acetylene torch you can buy a MAPP gas setup at home depot for around $30. If you break a stud off flush with the case because you didn't use heat, that $30 will look like a bargain. |
Hee hee, It was a while ago when I was in the area and Pretoria and JHB were closing in fast. I did like the goverment house gardens and (spelling) Oum Paul's house.
(spelling) Moy Blay, Bill. |
The studs have been replaced with regular steel ones. The old dilivars came out easily, surpringly perhaps. Maybe the car is starting to give me a break.
Thanks for everone's advise. Bill, it's "mooi bly", but you get 9/10 for effort. :D :cool: LeRoux |
| All times are GMT -8. The time now is 10:41 AM. |
