-   -   Should I replace the head studs? (http://forums.pelicanparts.com/porsche-911-technical-forum/207681-should-i-replace-head-studs.html)
LeRoux Strydom 02-21-2005 11:35 PM
My SC's engine is still apart, waiting for the cylinder heads to return from the engineering shop with new valve guides.
With the engine block on the bench, I took a magnet to the head studs. The intake rows were predictably magnetic, being steel, but the exhaust rows were not. Closer inspection revealed a colour difference from the upper row of steel studs. My mechanic was certain that all the studs were steel, until I did the magnet test.
Question: Should I now replace the dilivar studs with steel studs, given that they have lasted 27 years already? I could not see rust anywhere on them, but everything I have read says replace them. There is the risk of snapping the studs while attempting removal, but to me, this is a smaller risk than putting the engine back together and snapping a stud a few weeks/months down the line. I'm therefore leaning towards replacement.
Opinions?
LeRoux
ChrisBennet 02-21-2005 11:55 PM
I'd replace them. They seem to be more likely to fail soon after being disturbed.
-Chris
YTNUKLR 02-22-2005 12:01 AM
Several people have said not to re-use Dilivar studs. There's a guy on this board who re-used his dilivars on his 2.7 and within several hundred miles one broke and he had to tear down the motor part way and remove the stud! REPLACE, and get steel instead.
walt 02-22-2005 02:35 AM
Without a doubt - replace with steel while you have the opportunity.
Bill Verburg 02-22-2005 04:56 AM
I'd replace them w/ 993 versions
David 02-22-2005 05:12 AM
My opinion: replace with steel like the uppers.
Tim Hancock 02-22-2005 05:24 AM
Assuming you have the cylinders removed also, use a torch inside the case and pour some heat to it (it will take awhile as you are heat a large heat sink). Once the case area surrounding the stud gets hot, the studs will back out with very little torque required. I just did the same to my '79 SC (one of the dilivars cracked when the heads were removed).
If you do not use heat, you run the risk of breaking a stud off at the base and then you are in for some real fun.
Rot 911 02-22-2005 06:13 AM
Definitely replace!
rlane 02-22-2005 06:49 AM
see my poll on head studs..if it was my motor, alreadsy apart I would replace
sammyg2 02-22-2005 06:56 AM
You don't have to replace the dilavar studs now, you can do it in six months when one breaks ;)
Just being a smart a$$, yes you should definately replace the lower studs with steel. I used the 993 steel studs, relatively cheeep and work just fine.
Noel 02-22-2005 07:25 AM
Bill, why do you say the 993 versions? Just curious, as my SC had the 993 versions installed a few years ago after one broke.
Joe Bob 02-22-2005 07:35 AM
Give the divs the float test....go steel 993s like Sammy said...
Noel 02-22-2005 08:53 AM
Are the 993s steel?
aigel 02-22-2005 09:25 AM
Do you have the p/c removed? If not, that makes it an interesting question. Because you have to remove p/c to get to the studs. Unless you leave the pistons in the cylinders when you remove them, you are opening another can of worms. What if your pistons are worn, what if your cylinders are out of spec. What if you mess up and break a ring?
It can become a very slippery slope. Once the cylinders are off, you can then replace bearings on the crank and why not split the case while you are at it ... yada yada .... 5k later and you'll be SURE that nothing will every go wrong. :D
I am not saying that you should take any shortcuts, but weigh carefully how deep you go. If you do the work yourself it isn't that hard and expensive to go back later.
George
LeRoux Strydom 02-22-2005 10:42 AM
I'm already down the slippery slope - the engine is completely apart.
The overwhelming response confirms my view - replace. I'd go with 993 steel studs if I can find any locally.
Interestingly, in their defense, the dilivar studs survived 240000 km and at least one previous "rebuild", but I'm not taking any further chances. I do believe that the dilivars suffer from stress corrosion cracking, but the car has not seen any of the nasty climates that you all are used to. No ocean air or salty roads up here.
Thanks everyone for the advice.
LeRoux
Bill Douglas 02-22-2005 11:44 AM
Hey LeRoux, talking weather, what's your summer been like? Ours has been hot, dry and not much wind (not much wind for a change!). And has that last kilometer or two of open space between Pretoria and Jo'burg been built over up yet?
aigel 02-22-2005 01:07 PM
I know that Jerry Woods replaces them with the stock steel studs that you already have in the top rows. I think going with the 993 stuff may be overkill.
George
sammyg2 02-22-2005 02:02 PM
The 993 steel studs were actually cheaper than the stock SC steel upper studs (I bought them from Pelican).
So..... the 993 sateel studs are less money, they fit just right, and are plenty strong and should never fail.
I like the cheep part the most ;)
Noel 02-22-2005 04:20 PM
The 993 studs in the Pelican catalog are listed as Dilivar not Steel.
ChrisBennet 02-22-2005 06:32 PM
The 993 steel studs (part # 993.101.172.02) aren't listed with the head studs. But you can "find" them in the catalog if you look for the fctory part number.
http://forums.pelicanparts.com/uploa...1109125841.jpg
-Chris
