Sonic dB's Avatar
kuhi
kk
Old 02-25-2005, 08:23 PM
jpahemi's Avatar
Check the the position on the C clamp that holds the rubber elbow to the throttle body. The butterfly lever can come in contact with the C clamp tightening screw if the C clamp has been rotated to that area.
Regards,
J.P.
Old 02-25-2005, 09:32 PM
I had the spring break on my 3.2 once and it kind of did what yours did. Made the pedal feel very soft. If the spring is broken though it wouldn't get better by itself.
-Andy
Old 02-25-2005, 10:13 PM
Driving member
jester911's Avatar
Sonic, I had the same happen to me. The third time it happened I discovered the throttle cable to the cruise control
was hanging up.
My cruise hasn't worked since I have owned the car so I cut the cable.
It hasn't hung again and that was over year ago.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 02-26-2005, 02:56 AM
Not Quite Banned
Thomas Owen's Avatar
I second what J.P. said above - exactly what happened to me right after a rebuild. Have someone work the pedal while you inspect the linkage and cables for movement in the rear.
Good luck, and be careful until you definately find the problem -
Thomas Owen
1972 911T
1972 911S
Old 02-26-2005, 03:24 AM
I had my throttle stick a couple of times 5 years ago. Once when I floored the car leaving an airport parking lot toll booth. Very embarrasing besides dangerous. Turned out the linkage just needed some lubrication.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 02-26-2005, 07:50 AM
bigchillcar's Avatar
this happens to me everytime i get on an open highway...
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 02-26-2005, 07:53 AM
Sonic dB's Avatar
Thanks for the suggestions guys I will be under the car this weekend doing new swepco and some other things so it is a good time to check it out.
Old 02-26-2005, 08:28 AM
