Where to buy 930 r&p 8:41
Where can i buy one?
checked w/ carquip and powerhausii they want 2.2k Any used ones anyone know of?
Williamknightperformance.com Perfectpower.com |
I do know Andial has them, not sure what they want for them.
----------------------- '88 930 Slantnose Cabriolet '86 I-Class 944 fully prepped racer R1200GSA, S1000RR, R1100S, K1300S, K1200RS (x2), Harley XLCR, Vespas |
Andial had it when I was looking for it 8 months ago. Around 16-1700 bucks. Make sure its the German ones. If not, they whine like hell. Good luck, Jeff
I think I may go w/ andial, thanks guys
Do you have the stock gears? When you get the 8:41 R and P in there, it will feel like you have another 80 HP. 1st gear does suck.
I got 365 at the wheels also. CIS still? What kind of mods? |
Protomotive kit w/ intercooler but I am rebuilding the top end so it doesn't blow also for more boost
Doesn't want/need a 3.6L
The 8:41's were all Italian made at the time and were imported by both Chet Vicentz at Electrodyne (i.e. Racing Dynamics) and Chris Fisher at Powerhaus (the original PH). They did indeed whine like hell. As a comparison, assuming a 24.64 inch tire and 2.25/1.304/.893/.625 ratios, the 8:39 at 2,900 rpm is 69.8 mph in 4th gear and the 8:41 is at 66.4 mph at the same 2,900 rpm. Ralph |
Ralph, you are right about the 8:39 ratio. I am sorry. They did carry the 8:41 gear set.
Difference of 5 mph between the 2. What do you think Ralph? I went with many sleepless nights and couldn't decide and finally went with the lower ratio. It's a street car. |
So if I have a stock geared trans and I install a 9:39 r/p what would be my mph at 6800 rpms in each gear 1-4
45.52 mph 78.55 mph 114.70 mph 163.88 mph Ralph |
Ralph thank you I will be going w/ the 8:39
