-   -   88' Turbo Cab Realistic Value (http://forums.pelicanparts.com/porsche-911-technical-forum/208091-88-turbo-cab-realistic-value.html)
Huck 03-16-2005 01:07 PM
Just had a PPI and found 85% leakage at #6. All others were at 2%-3%. They said the leakage was from an exhaust valve. They are pulling valve cover now to check for a broken spring. What is a top end going to cost? I just called my buddy's machine shop and he said about $325 in machine work for all the heads (new seals, valve job and guides) Now looks like rings will be $500 and about 30 hours labor to R&R engine and cam towers along with cylinders. Does this sound right. Can it be done for $3500?
Huck
JeremyD 03-16-2005 01:16 PM
I have heard that quoted for top ends in Florida = heads only though - does it need to be reringed?
Huck 03-16-2005 01:20 PM
No but if I had it down that far I would put rings in it. That is a price from my buddy about 30 hours labor and $1000 in parts and machine work. I am calling another guy I know who runs a Porsche shop and see what he says.
Huck
Huck 03-16-2005 01:31 PM
Shop just called back and said they drove the car and let it warm up and rechecked the leakdown and it is now 4% or less. They checked it 3 times. He said it could of been carbon. How does this sound? ONly problem is a rear wheel bearing.
Huck
Huck 03-16-2005 01:59 PM
Huck
JeremyD 03-16-2005 02:10 PM
Sounds like they want to sell a car...
aigel 03-16-2005 02:15 PM
I would think that the shop would have driven and warmed up the car before doing the first leak down. I'd keep looking, unless you get to pay 5k less for a possible top end problem.
George
Huck 03-16-2005 02:18 PM
The shop is Foreign Affairs in Pompano Beach. I get a good feeling talking to them. I also called a local shop and a buddy who owns a machine shop and is big into Porsches and they both agreed it is a possibility that carbon could hold open an exhaust valve. What do you guys think.
Huck
JeremyD 03-16-2005 02:28 PM
It's a possibility - but it's also a possibility of something else... When buying a 30k - I try and eliminate the maybe's...
aigel 03-16-2005 02:30 PM
You can believe what you want. If I were serious about the car. I'd get a second opinion. Just like I would if one doctor would tell me I needed serious surgery. ;)
George
imcarthur 03-16-2005 02:39 PM
I have to go with caution here too. Can you get another wrench to do a leakdown?
Or at the very least (we all know you really, really want it) do a leakdown while you watch, so you can verify the results.
Ian
yasir 03-16-2005 02:39 PM
George
Couldn't agree any more and yes i will definately get a second opinion ;)
JeremyD 03-16-2005 03:39 PM
I think it's safe to say that in our own cars we can pick the faults - in a new car we tend to look at opportunities...
350HP930 03-16-2005 04:06 PM
If not carbon really sloppy valve guides can sometimes cause intermittent valve leakage.
Either way its better news than it possibly being a cylinder problem.
Older turbos usually are in need of a valve job by the time they start approaching 100K miles.
Huck 03-19-2005 07:28 AM
Well I bought the car. I had the mechanic do a leakdown while I was there and #6 was 4%. I had them do an oil change and balance the front tires. Just got home last night. Total I put about 1,000 miles on her. I mostly averaged about 80 - 85 mph and averaged 17 mpg. Best tank was 20 mpg. Much better than I thought. The car ran great and was much more comfortable than I expected on a 12 + hour road trip. Too bad the weather in Florida was rainy and too cold to put the top down. I am back in NC now and it might hit 64 today so I will put the top down. I am going to do a complete detail now. Thanks for all the help and answers. I will post some pics when I get her all cleaned up.
Huck
JP911 03-19-2005 07:54 AM
Congrats Huck! Can't wait to see more pics of this beauty. A turbo cab is on my list of P-cars to own sometime down the road.
350HP930 03-19-2005 08:31 AM
Wow, only 20 MPG? At 85 I used to be able to maintain a couple lbs of boost and average about 24 MPG.
JeremyD 03-19-2005 07:02 PM
Congrats!
5axis 03-19-2005 07:12 PM
Way to go. You now have a super cool 930 starter kit.
http://www.imagineauto.com/
Stephen is the man to fix you up with a HP junky starter kit. :)
Bolt ons for beginners are- K27 7200, SC cams, Kokeln IC, headers
maybe a 1 bar spring or boost controler too.
And can take you all the way to the big dogs $$$$$$$$$
david
89 turbo cab
5axis 03-19-2005 07:25 PM
Doh! just went back and checked the description in the original post.
You already got the basic goodies Very cool Put the top down and go fer a blast!
