Air Medal or two
machine weight off wheels??
Well I just got my set of Etoile Wheels they look terific,but they are built to semi truck specs!! HVY !!!! anyone know of who can carve 5 to 10 lbs out of these beast?? my car is little- weight wise I do not need all this.So anyone who has experiance on the yes side let me know.
I went from a 34 lb wheel to 45 lb wheel.......wrong direction here. (tire and wheel togather)HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
I wouldn't do it. You compromise the structural integity of the wheel. It was designed with that much metal for a reason.
Forged wheels are much lighter becuause a forging is much stronger than a casting. Thus a forged wheel can have much less metal and be just as strong as a heavier cast wheel. Don |
Air Medal or two
Now we got over that, anyone have any experiance except for the above?? Logic dictates if a 13 lb wheel will support a P. car then 22lbs is over kill. So thanks for the bump but need serious help,and not a doctor yet..............
13lbs of cash aluminum does not have the same strengh as 13lbs of forged aluminum.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Use Fuchs - there is nothing lighter or stronger for an early 911.
Cutting material off a cast wheel is a very BAD idea - the folks above are giving xlnt advice, not just bumps...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
If your wheels are cast, they will be heavier than forged Fuchs.
993 |
MBruns for President
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Air Medal or two
I know there are a lot of wheels lighter then the Fuchs.....just under logic dictates...a =amount of weight will=carry x amount weight-so w.o. getting into an emotional argument -whats right and wrong ,,I was thinkin I am not the only one with this problem .I guess the real problem is not able to afford a set of 4 to 8000.00 dollar set of wheels.
I tell ya there is so much material in these they could be on my semi...well almost
This will be your fate then
I think the phone dials are much cheaper than similiar fuchs - and you can usually pick those up for much less. My BBS wheels - 8x16 and 9x16 I picked up for $700...
Air Medal or two
I think there is more to that story then your telling us,- Bill?????
Somewhere in the Midwest
Don't do it!
Listen to these guys, they have nothing to gain with their posts. Ask yourself if a clay wheel weighing the same as your wheels will be up to the task of supporting your car under dynamic loading. The answer should be no! Material and construction determine the strength of the end product. You can't use basic mathematics or simple logic in place of engineering...esp. when your safety at risk. |
What weighs more, a 13 lb cast wheel or a 13 lb forged wheel?
I think your logic is flawed...possibly fatally so. They have to be heavier because they are cast and cast mettle is not as structurally sound as mettle that is forged.
"Casting has the advantage of allowing the designer more styling freedom because the process is a more flexible method. Until recently, most wheels have been gravity cast (heavier and thicker). Today, low pressure die casting techniques are used to substantially reduce porosity. Indeed, castings tend to contain porosity which strongly influences the mechanical integrity of the component. Thus, cast wheels are generally designed larger and heavier in order to achieve an acceptable structural strength for a given application." "The forged wheel, because of the enormous pressures involved, compacts the metal, eliminating porosity and the voids that can be a source for cracks or corrosion. The result is that less metal is required to achieve a given strength, meaning lighter wheels can be made. Furthermore, due to the density of the grain structure, the polished forged wheel will maintain its luster for much longer than a polished cast wheel which is very porous." PDF Doc of Forged vs. Casted wheels: http://www.calcom.ch/HomeWebCalcom/News&Events/actives/eTip16.pdf Article on forged vs. cast pistons: http://www.lcengineering.com/TechNotes/TechNote41.htm From Tire Rack: http://www.tirerack.com/wheels/tech/construc.jsp
87' Red Targa 10' Jeep Wrangler Unlimited 07' Subaru Impreza (lease ended) 02' Mini Cooper S (traded ![]() 91' VW G60 Corrado (sold ![]() Last edited by MysticAlpaca; 02-27-2005 at 05:10 PM.. |
LOL I just read that... [game show contestant voice]"hmmm Alex, I think the 13 lb wheel weighs more..."[/game show contestant voice] funny stuff...
87' Red Targa 10' Jeep Wrangler Unlimited 07' Subaru Impreza (lease ended) 02' Mini Cooper S (traded ![]() 91' VW G60 Corrado (sold ![]() |
Air Medal or two
ok allready
218lb Lap Timer
I DON'T KNOW THAT! .... AHHHHHH!!!!!!
...a total classic, Thom... ![]() Jojo
Jojo '84 3.2 Carrera Coupe '00 Jeep Grand Cherokee LTD "If everything seems under control, you're just not going fast enough" -Mario Andretti |
"a =amount of weight will=carry x amount weight"
- sounds like confusing wt. with the strength of the material - the strengths differ. I'd be interested to hear more about BBS wheels of the same size & strength as Fuchs but lighter. I've only been able to find one wheel lighter than the Fuchs (in that size) a custom Joenbloed of forged Mg - saves 1-2 lbs. and costs thousands...
