Wheels: "ET" v. "Backspace"
I'm selling some wheels.
The ET numbers are ET13 (8.5 inch wide wheel) and ET14 (10 inch wide wheel).
Some people have asked me what the "backspacing" is. Is it possible to calculate the backspacing from the above?
Old 02-25-2005, 08:51 PM
DinFtown's Avatar
Send a message via AIM to DinFtown Send a message via Yahoo to DinFtown
You have any pics?
David Walsh
77 911
04 ram
2 E30's 87'
and my John Deere
Http://www.ProBraking.com
Old 02-25-2005, 10:07 PM
ttweed's Avatar
Re: Wheels: "ET" v. "Backspace"
Yes, but you need to tell us the overall width of the wheel, from outside to outside edge of the rim beads.
It is probably easier to just measure it. Lay the wheel upside down and put a straightedge on the backside, spanning the rim edges. If the tire is still mounted, avoid laying the staightedge on the rubber--make sure it is on the rim edge only. Now measure perpendicular to the straightedge down to the hub mating surface. That measurement is the backspacing for the wheel.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 02-26-2005, 06:02 AM
Bill Verburg's Avatar
This diagram shows the relationship
As Thom said some measurement will be needed.
Bill Verburg
Old 02-26-2005, 06:29 AM
Got it, thanks!
Old 02-26-2005, 09:13 AM
another round please
strupgolf's Avatar
Bill, do you have any idea of the offset for a set of 18" Turbo Twist's from 96. Ive seen somewhere where the front is 48mm and back is 57mm. Does that sound about right. Thanks
Getting old is not for wimps.
Old 02-26-2005, 07:22 PM
