curlesw's Avatar
Shock and brake questions
I am getting ready to refresh my suspension and brakes and have a couple of questions. I know I have Bilstein shocks in the rear, it's clearly marked. See pic (well, you can't see it in the pic, but it's there):
I do not know what I have in the front...can anyone tell from the pic?
Also, when I turn the hub I can hear a scrapping sound...it's as if the brake pad is rubbing against the rotor. This is not normal, correct? I checked all the rotors and they are within spec but I plan to repalce the pads and flush the brake system.
Second, I assume the calipers are stock, are they?
Last, any idea what the dark lines on the wheel well are coming from the top of the front shocks...it's on both sides.
v/r
Wayne C.
83 SC
Old 02-25-2005, 04:53 PM
HarryD's Avatar
For the front, I would guess you have a Boge Strut with a Bilstein insert.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-25-2005, 05:11 PM
fancytown
Don't worry about the scraping unless it's hard to turn the rotor. If you can spin it, it's fine. Plus, with the wheel off, the rotor is loose. Try wiggling it...
all cars sold.
Old 02-25-2005, 05:20 PM
Have the same thing on my car- which I did. Bilstein inserts in Boge struts, Jerry
Old 02-26-2005, 06:22 PM
curlesw's Avatar
So if I want all Bilsteins then I guess I have to buy the entire struts/shocks for the front, correct? On the rear, should I buy new or have them refurb'ed?
v/r
Wayne C.
Old 02-28-2005, 08:10 AM
Yup. You have Bilstein inserts in Boge strut housings, I just did this last weekend. If you want an all Bilstein strut assembly, Pelican sells them.
Check Bilstein's site, they revalve for pretty cheap....
Here is the link:
http://www.bilstein.com/html/service/index.htm
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 02-28-2005, 08:21 AM
aj88cab's Avatar
Wayne,
You have Bilstiens at all four corners now. You can remove them and have them refurbished or you can replace them. There is no need to replace the front strut assembly unless it is damaged.
The original Boge assembly used the strut tube as the actual shock housing. That is why they are full of oil when you take them apart, they ARE the shock so to speak. The Bilsien insert uses the Boge strut/housing to hold the new Bilstien shock insert.
good luck
Andrew
Like chris said - i was a litle slow with my typing!
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 02-28-2005, 08:27 AM
curlesw's Avatar
Got it...thanks guys.
v/r
Wayne C.
83 SC
Old 02-28-2005, 10:20 AM
