Fuchs Sizing
Guys,
I thought the wheels on my 74 S were 8" fuchs. I was told this by the shop that put the tires on them. The tires are Yoko ES100s 205/60X15. I was there when the old tires came off and I measured the rims. They are 8" outside to outside and 7 1/2" inside to inside at the lip. What is considered the true size of these babies? |
Jim,
15x7s! They are also factory stamped on the inner spoke, wipe them off and the #'s will show. Thank you, Jason |
The meaning of the various terms used re wheels can be seen here
http://members.rennlist.com/1976c38/...AQ-diagram.gif When some one says that they have a x" rim they are(or at least should be) referring to the bead width which will be ~1" ± narrower than the overall width. |
Thank you Bill, That explains it. I appreciate your time.
| All times are GMT -8. The time now is 01:26 AM. |
