jplavanjr's Avatar
Exhaust studs & thread locker question
What (if any) color loctite should I use when installing new exhaust studs for the headers on my 2.0L race motor?
JP
'66 911 2.0 Vintage Racer
'11 997.2 C4S
Old 03-03-2005, 01:28 PM
Every recommendation I've seen is for Red Loctite on head studs.
Warren & Ron, may you rest in Peace.
Old 03-03-2005, 01:41 PM
I don't use locktight on exhaust,. I use antisieze, so I can get them off with out breaking the studs off in the case. Craig
80SC
Old 03-03-2005, 01:46 PM
I agree, anti seize.
Old 03-03-2005, 01:57 PM
ditto
although I would tend to agree with Craig, except I was reading a thread about fastners and Jim Sims or Randy Webb said it's a bad idea to not use red when attaching the studs to the heads.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-03-2005, 01:58 PM
I think it's red for studs into head and anti-seize on exposed end for nuts.
Old 03-03-2005, 02:12 PM
my act is nickel anti seize for all exhaust nuts.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-03-2005, 02:17 PM
From Warren:
"Red Loctite should be used on the threaded portion in the heads ... after chasing the threads with a tap, and degreasing thoroughly with brake cleaner/degreaser. Anti-sieze compound should be used on the nuts!"
Warren is also more specific in another thread in recommending Loctite Red #271 (NAPA). Hopefully he can verify.
Old 03-03-2005, 02:19 PM
Irrationally exuberant
ChrisBennet's Avatar
I personally wouldn't use any thread locker on the exhaust studs. Maybe I don't get out enough but I've never seen one come loose. Usually it's really hard to get them to come out at all.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-03-2005, 02:36 PM
Send a message via AIM to Oldporsche
Cool
I would use the anti-seize on the exposed threads. (any color)
Most of the time the stud has seized in the head anyway.
David Duffield
Old 03-03-2005, 03:57 PM
heat breaks down loctite. exhaust ports are damn hot. so loctite would probably be redundant in that application. i just put them in dry. anti-seize on the outer stud and nut.
206 637 4071
Old 03-03-2005, 04:01 PM
jplavanjr's Avatar
Thanks for all of the replies.
Still not sure what I'll do though. Seems to be split with: Red, anti-sieze, or nothing. Leaning towards nothing on the stud into the head, anti-sieze on the nut threads.
Anyone else to help me make the decision?
JP
'11 997.2 C4S
Old 03-03-2005, 06:28 PM
I just swap out my muffler/cat with Dansk sport stuff, I reuse the bolts and nuts, where can I buy a new set of these bolts and anti sieze, does local shop like auto zone sell them ?
TIA
911 1987 Triple Black Cab Turbo Look >> weekend car
SPF MK III Shelby Cobra 427 550HP >> thrill for speed
BMW 88 635CSi daily drive
BMW 87 325i use for rainning day (donation)
Benz 06 E350 use for pick-up kid on car pool day
Old 03-03-2005, 09:21 PM
Friday Morning bump.
Old 03-04-2005, 06:43 AM
JP:
Not to be a wise guy...but John Walker gives gold-plated advice and your very next post says "I don't know what to do".....
Here's MY advice.....take JW's advice .... Red loctite breaks down with heat and is redundant. Think of the head stud issue...those are loctited-in and require heat (usually) to remove. But cyl head area is HOT as a working environment.
Other experienced people note that it would have been nice to have anti-seize on the exposed portion that the nut rides on....good advice too.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-04-2005, 07:06 AM
Now, which nuts to use?
Take it away, Wil...
Old 03-04-2005, 07:25 AM
LOL!
Rick, I believe...is referring to my continued push of using Silicon/Bronze nuts as fasteners for the muffler portions of the car.
The problem here is that the size of the stud is ( I think) 8mm and I was not able to find Si/Br metric. Maybe stainless on a normal carbon steel stud with anti-seize ??? Anyone??
- Wil
Wil Ferch
Old 03-04-2005, 07:34 AM
any place that sell these type of bolts / nut ( SS or coper), I need a set for my new muffler
TIA
Old 03-04-2005, 09:26 AM
Originally posted by Wil Ferch
LOL!
that was funny in context.
so if you tell me yours, I'll tell you mine !
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-04-2005, 09:46 AM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
JP,
You said you always put your stud in DRY....LOL
Why question yourself now?
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 03-04-2005, 10:03 AM
