Meka's Avatar
Trim removal
Can anyone tell me how the plastic trim thats on the side of my 84 1911 is attatched? It's the one the runs accross the lower half of the doors.
Old 03-02-2005, 07:09 AM
i don't recall any plastic trim on the lower half of a 911 door.
206 637 4071
Old 03-02-2005, 07:48 AM
Take pictures and post. We'll tell you how.
On a correct 84 911, what you have is a pocket with a pocket flap.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-02-2005, 07:50 AM
kqw kqw is offline
The Fox
Carrera
Old 03-02-2005, 08:23 AM
Fast Eddy's Avatar
I believe you are refering to the rubber that runs on the rocker panel, it is set in a channel and should slide out once you remove the rocker end caps.
Old 03-02-2005, 09:21 AM
Meka's Avatar
Thats the one. Thanks Eddy!
Old 03-02-2005, 11:59 AM
Driving member
jester911's Avatar
First you need to unscrew the end caps on each end. Then just get down under the car and you will see some bolts that hold the bottom of the rocker panel to car. These bolts should have some plastic spacers.
Unscrew them and the panel will hang loosely from the screws holding it at the top. You should then be able to slide the rubber trim out of the rocker panel.
Then just remove the screws under the rubber
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 03-02-2005, 02:55 PM
