porschett's Avatar
Wink How do you know if you're flaming?
"Not that there's anything wrong with it" - Seinfeld
Seriously...Other than having someone drive behind you, how do you know when you're shooting flames? Does it happen on decel only? Between shifts only? It it followed by a popping sound? Can plugging the decel valve cause popping/flames?
I did spend an hour searching...I came accross one reply that unplugging the decel does cause flames, but wanted others opinion.
Reason why I ask is I have a high idle after warm up and trying to determine if it's the decel valve or AAR.
Thanks.
David Nguyen
1987 930: 2700 lbs, 408 RWHP/405 RWTQ
930 pics: http://alturl.com/899f9
930 Engine rebuild pics: http://alturl.com/25qcy
Old 03-06-2005, 10:48 PM
