-   -   Can you remove the tach from a 1984 911 without removing the steering cover? (http://forums.pelicanparts.com/porsche-911-technical-forum/209243-can-you-remove-tach-1984-911-without-removing-steering-cover.html)
Spede 03-03-2005 11:07 AM
Do I have to remove that top black plastic steering column cover to remove the tach from my 1984 911 or can you gently squeeze it out?
Spede 03-03-2005 02:22 PM
Anyone?
asphaltgambler 03-03-2005 02:36 PM
It looks close but when it is almost out use a little 'english' to get through the spoke opening.
porsche4me 03-03-2005 02:53 PM
put some tape or something on the plastic part before you start pullin - this way you wont mess up the plasic cover you have to see ......
Dont ask how I know this......... Dooh
scottb 03-03-2005 04:04 PM
I seem to recall there are just a couple of screws (four?) that hold the clamshell covers in place. Why not remove it and be on the safe side?
3.2 CAB 03-04-2005 03:13 AM
I tried to remove mine, and found that I did have to remove the cover to get the tach all the way out. Loosen the screws, pop off the cover, pull the tach.
