Where is the oil drain plug on a 3.3
I can't seem to locate a oil drain plug on my 3.3 turbo. I opened the large center drain on the bottom last time I changed the oil but I was wondering if there was a drain plug. Sorry for the stupid question. Also should I drain the oil out of the resevoir tank ?
1986 blk 930
2000 expedition
2000 bmw 3 series convertable
1996 Silverton 312 sedan bridge
Old 02-11-2005, 04:01 AM
If it's like my 3.2 you should be draining from 2 places...
1.) the oil tank
2.) a side-entry plug on the bottom/center of the engine case. Note--side entry, so look over nearer the dreiver's side ( of center)....you'll find it.
On a cold engine...you'll likely get 6 quarts from the engine....3 quarts from the tank.
On a recently shut down engine...expect 6 from the tank....3 from the engine.
Do a "search" on this topic..it's been posted a number of times before with additional detail. It would also help us ( to help you) if you post more detail of your car...year/model, etc...
Wil
EDIt...nevermind....I now see the car's detail on the bottom of your post...sorry.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-11-2005, 04:22 AM
Irrationally exuberant
ChrisBennet's Avatar
Like Will said, you should have a drain plug on the side at the lowest point but "large center drain" sounds like a sump plate motor. I think some of those did not have a drain plug. The cases changed in '83 from a big ~6" sump plate to just having a plug on the side so your '86 wouldn't have come with a sump plate motor.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-11-2005, 05:28 AM
Forced Induction Junkie
WERK I's Avatar
Here ya' go. Midsection of sump, drivers side.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-11-2005, 07:24 AM
Slant930's Avatar
By reservoir tank, do you mean the large one in the fender well or the small one under the turbo? Most of the oil will be in the large one, so I would definitely say to drain that. The little tank under the turbo will not have a lot of oil in it, but I would drain it anyways.
Tim
1983 930 w/ goodies
Old 02-11-2005, 08:03 AM
The bottom of my motor does not look like that. In the center is a large 6" circle with I think 8 small nuts that when removed the oil comes out and there is a screen on top, the bottom of my motor is flat. This is not the original motor or tranny ( 5spd) how do I tell what year?
1986 blk 930
2000 expedition
Old 02-11-2005, 11:35 AM
The center cover has lost its drain bolt over the years. Now the dealer won't sell the old type with the threaded plug, which is a dirty shame if you ask me.
Your engine got a new sump plate sometime in the past.
Old 02-11-2005, 12:06 PM
You have an 83 ( or pre-83) block....as ChrisBennet described....
Look near the fan support....on the right side...vertical surface....hard to read. You'll find something like 64XXXX
Near that...to *its* right....but now flat on the upper surface of the engine is another number...like 930/21
Get those numbers and some of us can do a trace....
Wil
Wil Ferch
Old 02-11-2005, 12:09 PM
Do you mean between the a/c support and the fan ?
1986 blk 930
2000 expedition
Old 02-11-2005, 12:33 PM
O.K. I looked in my bentley manual where the #'s are supposed to be. The fan support has no numbers what so ever and the #'s on the tag near the oil sender are worn off. Where else can I look ?
1986 blk 930
2000 expedition
Old 02-12-2005, 08:30 AM
They *are* there...but are often very faint....clean carefully and check with a high intensity , narrow beam flashlight.
If truly gone, there are no other meaningful numbers...maybe only side-of-case just above the oil return tubes....930.XX.XXX.XX...tells what kind of "basic" engine case you have...
Wil
Wil Ferch
Old 02-12-2005, 09:11 AM
Automotive Monomaniac
Emission's Avatar
Purdy. Makes mine look like a mess...
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 02-12-2005, 09:16 AM
Here are some numbers I found 930 1051112r mean anything ?
1986 blk 930
2000 expedition
Old 02-13-2005, 08:00 AM
WERK I's Avatar
Steven,
That is the engine case part number. The number Will was referring to is located in the photo provided.
Dave
Old 02-13-2005, 08:43 AM
WERK I's Avatar
Here's the other number.
Dave
Old 02-13-2005, 08:45 AM
Thanks Dave...that's exactly correct and for those that have Bruce Anderson's Performance book....it may be clear from those pics, too.
Wil
Wil Ferch
Old 02-13-2005, 10:46 AM
I finally was able to get under my car, on the driver's side near the transmission is a 1" round slotted flated head screw facing down. Is this by chance the oil drain ? It is not alloy and seems near where you guys have pointed with the pictures.
1986 blk 930
2000 expedition
Old 03-05-2005, 08:04 AM
No, the slotted plug is an oil relief valve. Find the lowest point on the motor, in the middle of a large round plate should be a plug that takes a 15mm (?) socket. Some motors lack the plug and require you to remove the whole sump plate.
-Chris
Old 03-05-2005, 08:23 AM
beepbeep's Avatar
Jeeez...you guys make it sound like a brain-surgery
Steven:
you need to open two plugs.
This one:
...and this one:
There lot's of oil (~11 quarts), be prepared. Don't check oil-level after refill without engine running! Use good full syntetic oil (whathever leakage-conspirationists say).
Clear?
Thank you for your time,
Old 03-05-2005, 10:10 AM
PorscheGuy79's Avatar
Steven:
This one:
What Steven is saying is that he doesnt have that drain plug, just the sump plate. Steven you might have to just remove the sump plate every time in conjuntion with the oil tank. Goodluck.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 03-05-2005, 10:21 AM
