| Registered |
				Where is the oil drain plug on a 3.3
			I can't seem to locate a oil drain plug on my 3.3 turbo. I opened the large center drain on the bottom last time I changed the oil but I was wondering if there was a drain plug. Sorry for the stupid question. Also should I drain the oil out of the resevoir tank ?
				__________________ 1986 blk 930 2000 expedition 2000 bmw 3 series convertable 1996 Silverton 312 sedan bridge | ||
|  02-11-2005, 04:01 AM |
| Registered Join Date: Aug 2002 Location: Galivants Ferry, SC
			If it's like my 3.2 you should be draining from 2 places... 1.) the oil tank 2.) a side-entry plug on the bottom/center of the engine case. Note--side entry, so look over nearer the dreiver's side ( of center)....you'll find it. On a cold engine...you'll likely get 6 quarts from the engine....3 quarts from the tank. On a recently shut down engine...expect 6 from the tank....3 from the engine. Do a "search" on this topic..it's been posted a number of times before with additional detail. It would also help us ( to help you) if you post more detail of your car...year/model, etc... Wil  EDIt...nevermind....I now see the car's detail on the bottom of your post...sorry.
				__________________ Wil Ferch 85 Carrera ( gone, but not forgotten ) | ||
|  02-11-2005, 04:22 AM |
| Irrationally exuberant |
			Like Will said, you should have a drain plug on the side at the lowest point but "large center drain" sounds like a sump plate motor. I think some of those did not have a drain plug. The cases changed in '83 from a big ~6" sump plate to just having a plug on the side so your '86 wouldn't have come with a sump plate motor. -Chris
				__________________ '80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ | ||
|  02-11-2005, 05:28 AM |
| Forced Induction Junkie |
			Here ya' go. Midsection of sump, drivers side.
				__________________ Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P | ||
|  02-11-2005, 07:24 AM |
| Registered Join Date: Apr 2003 Location: Austin, TX
			By reservoir tank, do you mean the large one in the fender well or the small one under the turbo?  Most of the oil will be in the large one, so I would definitely say to drain that.  The little tank under the turbo will not have a lot of oil in it, but I would drain it anyways.
				__________________ Tim 1983 930 w/ goodies | ||
|  02-11-2005, 08:03 AM |
| Registered |
			The bottom of my motor does not look like that. In the center is a large 6" circle with I think 8 small nuts that when removed the oil comes out and there is a screen on top, the bottom of my motor is flat. This is not the original motor or tranny ( 5spd) how do I tell what year?
|  02-11-2005, 11:35 AM |
| Registered Join Date: Jun 2000
			The center cover has lost its drain bolt over the years. Now the dealer won't sell the old type with the threaded plug, which is a dirty shame if you ask me. Your engine got a new sump plate sometime in the past. | ||
|  02-11-2005, 12:06 PM |
			You have an 83 ( or pre-83) block....as ChrisBennet described.... Look near the fan support....on the right side...vertical surface....hard to read. You'll find something like 64XXXX Near that...to *its* right....but now flat on the upper surface of the engine is another number...like 930/21 Get those numbers and some of us can do a trace.... Wil
|  02-11-2005, 12:09 PM |
| Registered |
			Do you mean between the a/c support and the fan ?
|  02-11-2005, 12:33 PM |
| Registered |
			O.K. I looked in my bentley manual where the #'s are supposed to be. The fan support has no numbers what so ever and the #'s on the tag near the oil sender are worn off. Where else can I look ?
|  02-12-2005, 08:30 AM |
			They *are* there...but are often very faint....clean carefully and check with a high intensity , narrow beam flashlight.  If truly gone, there are no other meaningful numbers...maybe only side-of-case just above the oil return tubes....930.XX.XXX.XX...tells what kind of "basic" engine case you have... Wil
|  02-12-2005, 09:11 AM |
| Automotive Monomaniac | Quote:
				__________________ 2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) | ||
|  02-12-2005, 09:16 AM |
| Registered |
			Here are some numbers I found 930 1051112r mean anything ?
|  02-13-2005, 08:00 AM |
			Steven, That is the engine case part number. The number Will was referring to is located in the photo provided.
|  02-13-2005, 08:43 AM |
			Here's the other number.
|  02-13-2005, 08:45 AM |
			Thanks Dave...that's exactly correct and for those that have Bruce Anderson's Performance book....it may be clear from those pics, too. Wil
|  02-13-2005, 10:46 AM |
| Registered |
			I finally was able to get under my car, on the driver's side near the transmission is a 1" round slotted flated head  screw facing down. Is this by chance the oil drain ? It is not alloy and seems near where you guys have pointed with the pictures.
|  03-05-2005, 08:04 AM |
| Irrationally exuberant | Quote:
 -Chris
				__________________ '80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 03-05-2005 at 08:27 AM.. | ||
|  03-05-2005, 08:23 AM |
| Registered Join Date: Jun 2001 Location: Sweden
			Jeeez...you guys make it sound like a brain-surgery      Steven: you need to open two plugs. This one:  ...and this one:  There lot's of oil (~11 quarts), be prepared. Don't check oil-level after refill without engine running! Use good full syntetic oil (whathever leakage-conspirationists say). Clear?
				__________________ Thank you for your time, Last edited by beepbeep; 03-05-2005 at 10:14 AM.. | ||
|  03-05-2005, 10:10 AM |
| Registered | Quote:
				__________________ Matthew “Sometimes the questions are complicated and the answers are simple.” | ||
|  03-05-2005, 10:21 AM |
