Virginia Rocks!
VaSteve's Avatar
Flywheel Seal Help!
I bought a flywheel seal (from another vendor ) and I'm not sure I got the right one.
I removed a reddish one with the following markings:
Kaco D6 90 1110 12101
and installed a black one with the following:
Kaco FPM DFS 90 110 12LTF08 Porsche 999.118.426.41
The new one didn't seem to be the exact shape as the old one and additionally, I couldn't insert it flush with the case as JW recommends. I pushed it in as far as I could without really wailing on it.
Thoughts? (Do I just need to hit it harder?)
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 01-03-2005, 06:55 PM
AFJuvat's Avatar
I tap them in using a hammer and a small wooden block. They should tap in flush with the case.
The part number should be 999.113.426.41 I think you mistyped the number
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-03-2005, 07:04 PM
Virginia Rocks!
VaSteve's Avatar
I checked and I did mistype the number. I just went out and tried the wood block. That appears to be the ticket. Thanks!
Old 01-03-2005, 07:12 PM
Good to see some progress!
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 01-03-2005, 07:54 PM
Virginia Rocks!
VaSteve's Avatar
For the record, I have either installed this wrong, or used the wrong part. It's leaking pretty bad. Looks like I will be doing it again.
Old 03-05-2005, 05:09 PM
blue82coupe's Avatar
VaSteve. If thats a photo of your install , then part of the problem is the cleanliness of the flywheel area. It needs to be very clean. The machined groove around the seal should be clean of grease and oil. Use a solvent,such as brake cleaner. The lip of the seal should be lubed with oil or assembly lube and the grooved outter portion should be installed dry or with blue or green thread locker. Anyhow thats been my experience with flywheel seals. Hope this helps.Dan
I have plenty of lead for my pencil... just not enough paper to write on..
82SC with 95 993 engine
2004 Ford Powerstroke
Old 03-05-2005, 05:40 PM
Virginia Rocks!
VaSteve's Avatar
Yup. That's my install. Thanks for the tip. I will use is when I do it again.
But, regarding assembly lube, check this out. I don't know the specifics, but surflovers leaked worse:
Moral support update!
Old 03-05-2005, 06:14 PM
VaSteve. I'm pretty sure he made the mistake of putting assembly lube on the outter surface of the seal. The part that seals against the case. The assembly lube allowed it to poop out under oil system pressure. Dan
Old 03-05-2005, 07:12 PM
