| Registered Join Date: Feb 2003 Location: Hiding from the masses
				Duel Master Cylinder Setup
			I was wondering if there were other options then the Fabcar setup which cost $750. I am getting ready to install 993 brakes and wondering how much more then a 930 M/C in would cost. Thanks for any help Thom
				__________________ Thom '81 SC Euro Money Pit #1 '02 Boxster S "Econo Car" (or at least thats what I told the wife) | ||
|  03-06-2005, 05:37 PM |
| Moderator |
			you don't need the dual master setup, just get either the 23mm ATE for non boosted or late 930 for boosted brakes There are several threads, try a search on "901shp"
				__________________ Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | | ||
|  03-06-2005, 06:15 PM |
| Registered |
				newer m/c on 72
			I'm in the process of building a 72 rs clone using the parts off of my 84 carrera.  My m/c is the 23mm with booster.  I am running boxster monoblocs up front and 944 T brakes in the rear.  How can I fit my 84 m/c into the 72 car? Or how can I generate enough brake pressure using another setup? thanks!
				__________________ 996 Coupe, 84 Euro Carrera, Cayenne S, BMW CS 30, 72 2002 Ti (gone) 72 911 Hot Rod, Healey 100M, Giulia 1300 Ti, Merc 280SE4.5 Colorado Grand 03-04-05-07-08-11-17-18 Tour Auto 04-05 RG #650 | ||
|  03-06-2005, 07:12 PM |
| Registered Join Date: Mar 2004 Location: City of Seattle, WA
			I think the easiest thing for you to do eric is to install the 23mm ATE as bill mentioned, often referred to as the "Mercedes master cyliinder" because it comes from a mercedes truck.  If you search for what I quoted you should find lots of information.  The major thing is that the MC mounting for power brake cars is much different than non-power.  conversion can be done, but it's easier not to. unimog ... sweet.
				__________________ Andy | ||
|  03-06-2005, 07:25 PM |
