moosthuizen's Avatar
CV or clutch?
I've been getting a kind of grinding noise from the back of the car if I turn to the left. This will happen even at low speeds, and with a minimal of weight being placed on the right back wheel.
Is it one or both of the CV's or anything else? I'm excluding the wheal bearing, as I dont think the sound is that of a warn bearing.
So I jacked up the car, with the right rear wheel in the air. I started the car, with it in neutral I noticed the wheel slowly spinning. Is this normal? With the car in the air I could not hear the same noise again.
Thanks for your assistance.
Marius
M Oosthuizen
'87 Carrera
'80 SC Sold
Old 03-14-2005, 01:33 AM
IROC's Avatar
Just a suggestion, but try turning left and pushing the clutch in during the turn and then see if the sound changes/goes away/stays the same. If it goes away, then I would suspect CV joints or something driveline related. If the sound doesn't change, then I would look at the rear wheel bearing, etc.
HTH.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 03-14-2005, 04:31 AM
Thanks Mike,
That test slip my mind. I'll give it a go today.
Marius
M Oosthuizen
M Oosthuizen
'87 Carrera
'80 SC Sold
Old 03-14-2005, 05:19 AM
