-   -   Warren/Grady/GeorgeK anyone..explain this 934/935 CDI box (http://forums.pelicanparts.com/porsche-911-technical-forum/209853-warren-grady-georgek-anyone-explain-934-935-cdi-box.html)
MotoSook 03-07-2005 01:11 PM
Someone posted an ad in the classifieds...interesting. Looks like a potentiometer to retard or advance ignition...is that right?
Please enlighten this idiot :)
http://forums.pelicanparts.com/uploa...1110218449.jpg
Early_S_Man 03-07-2005 01:33 PM
Souk,
Per Paul Frere,935 distributors had no centrifugal advance mechanism ... where you dialed the dist. body to, and tightened the nut -- that's it!!!
Although I have no experience with 935s -- so don't take this as Gospel ... it would be very easy to build a variable delay stage either ahead of, or after the Schmitt Trigger of the 6-pin CDI unit. All it could do would delay the spark for a retard effect, so the distributor body adjustment would have to be dialed-in and bolted down with slightly more advance than normally needed ... and then the dial on the CDI box could be used to set and mark known advance settings. Makes a lot of sense when you think how hard on the skin of the hands it must have been to loosen and tighten the hold-down nut for the dual-plug distributor of a 935 engine! Asbestos octopus or gloves would have been handy ... just like in the days of the 550 Spyder!
racing97 03-09-2005 01:28 PM
This is a Rev Limiter on a Bosch Motorsport CD box. They moved a bit in use in 935's and were a bit finicky.
Best regards
emcon5 03-09-2005 01:49 PM
That almost looks like a aircraft style circuit breaker.
Tom
