Wider is Better
Old wires--replace??
My car ('87 Carrera) runs great and idles smoothly. At night I see no arcing around the plug wires, but the exterior insulation is so brittle I can peel pieces off with my fingernails. The car is new to me so I do not know how long the wires have been in there.
Am I looking at an ignition failure waiting to happen? My inclination is to replace them, but I guess I just want reassurance that I am not breaking the "if it ain't broke, don't fix it" maxim.
Wider is Better |
If it were mine, I'd definately replace them.
Jerry M '78 SC |
I would replace them, and the plugs, cap, rotor, oil change, tranny fluid, gas filter, air filter, and any other hoses that are suspect on the car.
Now you know what you have.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Wider is Better
Hijacking my own thread
OK, I will replace the wires so I know what I have. When I purchased this car, I took it to a Porsche shop and they adjusted the valves, changed oil, cap, rotor, air filter, flushed brakes.
I will replace the old wires, plugs, fuel filter, and check hoses. Is there anything else I should do so I "know what I have"? Repack/replace wheel bearings? Anything else? Non-critical repairs it needs: Drivers door does not lock (yes, I've done a search) Buzzer does not work when lights are left on Gas gauge sticks sometimes (sending unit, I presume) The car has 88,000 miles and averaged about 1500 miles/year for the last 10 years (according to Carfax). All suggestions/ideas are welcome.
Wider is Better |
Re: Hijacking my own thread
