nigel911's Avatar
Value please
Had new tensioners fitted at the cost of $1009 last week, then car packs up 9 miles down the road. The shop has looked at the car and checked the tensioners which are apparently fine. Without dismantling the top-end to verify they believe the engine may have thrown a valve, unfortunately it was just bad luck and a coincidence it happened so soon after the tensioner issue.
They reckon 'IF' it is a valve the cost will be around $2500-3000 to put right, more if it is anything else surfaces...
Here's the deal - I have just moved house and believe it or not the car (until now) has been my daily driver, I am not in the best financial position at the moment and am now car-less and have limited options. What I want from you guys is an idea of what the car would sell for AS IS.
I have had the car for 3 and a half years and have several+ thousand dollars worth of receipts on top of what I paid for the car. Just some of what has been done/replaced:
* New rotors all round, rebuilt calipers + new hardware
* SS lines, speed bleeders
* New Turbo tie-rods and ball-joints
* New half shafts
* New interior - seats recovered, RS door panels, carpet kit, floor mats
* Motolito wheel & Adapter, new window cranks
* New sunvisors, gearknob, luggage straps
* New retracting seat belts from PEP
* New carpet kit in trunk, new hood shocks
* Guages rebuilt
* New Blaupunkt head unit, Polk 6.5s in doors, Polk 4s in parcel shelf
* Pertronix fitted, new wire set
* Targa top reconditioned, new top clips
* New shocks throughout
* New engine & trannie mounts
* ALL bushings replaced - trailing arm, sway bars etc
* New neatrix rear spring plate bushings and new spring plate covers
* New Shifter bushings & rebuilt pedal cluster
* New Euro lenses, new horn covers, H4s
* New Euro bumper guards front & rear (chrome, no rubber strip)
* Strut Tower Brace
* Turbo valve covers
* Oil sump plate kit
* Polished 7x15s rears, polished 6x15s front (deep sixes), new black lugs
* New hood emblem / badges throughout
* Odyssey single battery conversion and quick disconnect
* New carrera tensioner kit (only 9 miles on them!)
72T Targa in signal yellow. Car is solid and in very good overall condition, always been reliable until now. Minor rust bubbles at bottom of doors, offside front fender has minor bubbling, floor pan solid. Car has factory AC. Always maintained, swepco, regular oil and valve adjusts etc. Still runs original MFi.
Old 03-08-2005, 03:45 PM
Crusty Conservative
silverc4s's Avatar
Soooo, my first reaction is . If it indeed threw a valve 9 miles after tensioner replacement - AND the shop maintains that their work was unrelated to this failure??? Are you prepared to take them at their word?
They were working on the very same system, and there are a couple of installation errors that can cause the cam timing to slip, this being the end result in most of those cases....
What is your very pretty Targa worth? I would say that it's value AS-IS is about $5K to $10K LESS than it was before this shop work was done, depending on how much risk the new owner is willing to undertake.
How many miles on the engine, and has major or top end overhaul ever been done??
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 03-08-2005, 03:59 PM
Now in 993 land ...
aigel's Avatar
What Bill says. That's a bit too much "coincidence" for my taste. Valves don't just fall into the cylinder.
Your car, if nothing has been opened up again can be examined and it can be verified if piston to valve clearance / cam timing is compromised after the 'repair'.
I would go at it and make the shop responsible 100%. At least get them to repair it for free and you'll pay for the machine work and parts, their price.
George
81 SC (sold)
Old 03-08-2005, 04:05 PM
Jays72T's Avatar
Beautiful car, sorry to hear what happened. It sounds fishy, you drive the car for over 3 years and then after new tensioners it fails? I would get a second opinion. As for what it's worth... eaarly cars are going up and even with a bad motor that car looks great and has a lot of work done. I'd say you could get around $8000 on ebya.
Good luck with it.
Jay
'08 E350 Wagon
'74 914 gone
'72 T gone
Old 03-08-2005, 04:10 PM
nigel911's Avatar
I am in a really crappy position and I truly hate being here.
Surely the car would not have run at all if the tensioners had been ill-fitted? The guy is well respected in the area and has worked exclusively on Porsches for 25+ years. The car was flat-bedded back to his shop on Friday half an hour after I had collected it, he maintains the failure was unrelated to the new tensioners and he apparently removed the chain covers and everything was as it should be. I do not know enough to doubt him (or better yet prove him wrong), what would you do?
I bought the car with very little history from a PCA member. Had it inspected, all was good. No idea as to the miles or rebuilds.
Old 03-08-2005, 04:14 PM
Crusty Conservative
silverc4s's Avatar
nigel911,
Was this a first installation of pressurized tensioners, or a replacement of the 1972 style originals?
What else was replaced parts-wise? Items like ramps, idler sprockets, etc??
Do you have a materials list from the invoice??
Bill
nigel911's Avatar
Just listed on the invoice as 'chain tensioner update kit - $600'
First installation of tensioners to replace originals - as far as I know. My lack of technical knowledge is kicking my a$$ on this one. I don't know what to do.
Old 03-08-2005, 04:28 PM
Crusty Conservative
silverc4s's Avatar
That sounds like the "Carrera" tensioners; they are what is generally involved when an "update" is referred to.
Is the car at your home now, or back at the shop?
There are far more knowledgeable folks that I here on this procedure, but it is definitely beyond minor surgery, and can be the cause of such a failure if camshaft timing slips a tooth while in process.
The timing of your cams can be checked RIGHT NOW, by a competent technician. You should consider having that done independently before finalizing dealings with the last shop.
You might stop payment on the $1009 too, if there's a way to do that, pending some resolution.
I am just telling you what I would do in this case, this is not in any way legal advise, YMMV...;-)
Bill
Old 03-08-2005, 04:40 PM
sundaypunch's Avatar
You need to look into this further. I also do not believe that you have the tensioners repaired and then 10 minutes into a drive you have valve failure that is unrelated. That is highly improbable. Of course the shop is going to tell you it is unrelated, they don't want to be forced to repair the motor. There have been several threads here over the past couple of years from people that damaged their engines after installing new tensioners. Sorry, I don't have them bookmarked but I did read the horror stories before (successfully) redoing mine.
I would have it towed to another reputable Porsche shop for an inspection. I would never have the same shop do the work on the top end if you have it rebuilt unless it is for free.
Ultimately these things often come down to the amount of inconvenience you are willing to go through. Most people don't follow through and end up being out the money while the shop gets away with it.
Old 03-08-2005, 04:43 PM
Blockchain Tech Inventor
jrdavid68's Avatar
Since no one has really answered your question, I'll take a stab at it and say that you would probably get somewhere between $2500 - $4000 AS IS.
A Mean Green Lifted 1972 C10
Long live the king!
Old 03-08-2005, 05:09 PM
Crusty Conservative
silverc4s's Avatar
Whew! JR, you must be a loyal follower of Sweet old Bruce!!;...(
Bill
Old 03-08-2005, 05:12 PM
chuckw951's Avatar
Value? $6-7K maybe? Having a toasted motor always hurts the value of a porsche.
I too think what has happened here is related to botch installation of the chain tensioners. Or may be defective chain tensioners? I thought I read something about people running into bad batches of tensioners upgrade kits?
If chain tensioners fail timing goes off big time. Things collide. Big mess.
In my 1978 targa 3.0 I was driving on an autocross and the engine jumped time. I was cruising along through the cones and snap! Oh that sounded expensive. Pulled the motor apart (well I didn't, mechanic did) and found some bent valves and cam timing was all screwed up. Anyway we are not sure what happened as the tensioners were in good shape and did not collapse. Anyway I guess my point is that this sure sounds related to the recent work done.
I think the shop has to prove to you that the two events were not related. You need a second opinion. Perhaps file a suit in small claims court too to show you are serious.
Even if the shop is "well respected" I can't how they can rule out the work they did as the cause without getting into the motor.
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler
Old 03-08-2005, 05:23 PM
Now in 993 land ...
aigel's Avatar
There isn't much you can do since the car went back to them. If there was a cam timing problem or a tensioner collapsed, it probably is fixed now.
I would still threaten the shop with legal consequences, if they do not work with you. You can tell them that you will take them to small claims and that you will provide an expert witness that will tell them that it is highly unlikely that the work and the engine failure are not related. You may hope to get at least the labor back for the work that was performed.
George
81 SC (sold)
Old 03-08-2005, 05:25 PM
MBruns for President
JeremyD's Avatar
Nigel - talk to Joe at Germantech in St. Petersburg - www.germantech.com he is probably the best wrench I have run into in a long time - and as straight as the day is long... I too would have a hard time believing one is not related to the other
Old 03-08-2005, 05:28 PM
Now in 993 land ...
aigel's Avatar
To answer you actual question: Your car is worth about 10k with a running engine, I'd say. Subtract for the engine repairs accordingly. I would think it will be tough to get more than 6k right now, since the engine will likely need more refreshening than just popping one head off.
George
81 SC (sold)
Old 03-08-2005, 05:31 PM
on-ramp's Avatar
if i paid a shop over a grand, then into the first 10 minutes, the car dies, they better start saying their prayers. there's no way the car would've gone back to them.
get the car back ASAP and get a strong second opinion and then sue them, get your money back plus damages.
Old 03-08-2005, 05:34 PM
Lets see $2k-$4k for car, $6k for a 3.2l engine, sell core for $1k. Thats $7k-$9k for a pretty sweet early targa with a 3.2.
Yes please!
Old 03-08-2005, 05:35 PM
JeremyD's Avatar
I hear you - or better hire a security guard for my return or I'd be taking out the one k on someone's hide...
Old 03-08-2005, 05:43 PM
Team California
speeder's Avatar
What George said. "Highly unlikely", and that is putting it politely. Did the cam timing slip? What did the shop say? How much fiddling around have they done w/ it since it was towed back to them? I would get it the hell out of their shop immediately and stop payment on the $1009.00 until you can clear it up, 10 minutes out of their shop is enough of a "correlation" for any BAR or court that I know of. Especially when the mechanical failure is 100% related to the system on the motor that they were working on. This is ridiculous, they are absolutely taking advantage of your limited mechanical knowledge, this would not fly for 10 seconds w/ most owners!
Even if they have "fixed" the cam timing, all of the evidence is still there. Unless they switched in a different tensioner, but then they are opening up themselves to massive exposure for fraud, perjury, and possibly other criminal charges that could have their shop padlocked immediately, at least here in CA. None of the shops that I recommend on this forum would dream of throwing away their entire business over a mishap like this. It's inconceivable.
As for what a 911T targa w/ a broken/non-running motor is worth, that is a sad subject. If anyone tells you more than ~$3-4k, ask them if they or anyone they know would like to buy it for *their suggested price*. That will shut them up in a hurry.
Denis
Old 03-08-2005, 05:50 PM
I'm agree with the general sentiment here that it was the shop's fault and, now, liability. Squeaky wheel gets the grease.
I'd first take a strong stance that they pay for all of it, but I liked the suggestion that you pay for machining and parts, and they pay for labor. That is a very fair comprimise.
I'll start the real-money bid war at $4500, as-is. But really, you shouldn't sell it for that.
E
Old 03-08-2005, 06:11 PM
