Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
7x17 fronts, what tires fit
Hey guys, gonna be putting some new rubber on the 912-6 in the next few weeks. Gonna bond on the sc flares on the back (watch for the flare party in NC in a few weeks) so I can put the 9x17's in the back with 255 40 17 rubber, either a kuhmo or toyo tire.
I've got 3 sizes of tires available for the front, the size will determine which brand I buy. Choices are:
205 50 17 - toyo ra1
205 40 17 - toyo ra1
225 45 17 - kuhmo victoracer
Whats gonna work better, having the 225/255 stagger, or the 205/255? Whats gonna fit under the narrow front?
Currently I have yok es100 205 45 17's on the car.
Thanks!
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 03-16-2005, 05:11 AM
Too many variables....
You didn't mention wheel width or offset/backspace, either....
Data point: 17 x 7.5 can work with a 37mm offset...can't recall tire size, probably a 215.
8x18 can work in front ( say some) with a 30 mm offset, 225/40-18.
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-16-2005, 01:56 PM
Bill Verburg's Avatar
Alongthe lines of Wills thinking, as long as o/s is correct I would want 225/45f to go w/ 255/40r
I further think that you may not be happy w/ the effect of those taller tires on your gearing.
Bill Verburg
Old 03-16-2005, 02:04 PM
adomakin's Avatar
what are you using to bond your flares on John?
Andy
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 03-16-2005, 03:54 PM
Stahlwerks.com
jhelgesen's Avatar
I'm already running 205/45 tires on the rims, 55 offset and 3/4" spacers in the front, will have a set of 1" spacers when I change the rear rims soon. Wondering if the 225's will work. Haven't found a 215 tire in the victoracers or ra1's.
Checked the tire size calculators and the 255/40's are only .7" larger in diameter that what I've got, and they are closer to factory size that what I'm running, plus I run out of gear alot on the track, could use a little larger tire.
John Helgesen
Old 03-16-2005, 04:05 PM
Stahlwerks.com
jhelgesen's Avatar
Planning on using 3m panel adhesive.
John Helgesen
Old 03-16-2005, 04:06 PM
