Brembo GTP's & Master Cylinder Ideas
Ok I am installing Brembo GTP's front and rear but someone said the Turbo Master Cylinder upgrade still was not enough for these brakes.
True or False? I have the 84 boosted master setup and was going to go up to a turbo master but if this is not enough then maybe I could build a mount for the booster to push dual 25's. Has anyone done this?? Any Input from the Brake guys?? |
The other alternative is a Smart Racing boosted dual master setup which can be had w/ twin x1" masters. |
So is it a straight swap on the 23.81 or do I need a bias valve?
Woo 35.4 993tt not trivial - sounds like my kind of fun :D |
the 930 m/c is a straight swap, there are some wiring differences for the stoplight and warning switches on some cars, its a matter of 2 wire vs 1 wire hook up.
The preproduction #s supplied to me by Race Tech(Brembo) indicate an extreme front bias(another reason I didn't like them) the production versions currently being supplied may be better in this regard, I really do not know. Please check and let us know what pistons they are being shipped w/. A better evaluation of bias can be supplied at that time. |
Thanks Bill,
I will let you know what I find!! Anyone want to buy a new 84 OEM Master??? I have one :D |
Ran the GTP-LW with a 23 MC with no issues at Sebring. Pedal was high and hard...
Cheers, James |
Thanks James!
Hey Bill, I'll get them in the next few weeks. Sorry about that but I have had a very steady stream of cars coming in for some major fabrication work and haven't had any time.
Cheers, James |
One last thing, if the GTPs are as front biased as the preliminary #s suggest, then a dual master setup will be very desirable.
Ok back to that:
What about taking the 84 OEM booster, removing the OEM master , CNC'ing a dual master mounting system with ballance bar and having the booster drive the two masters? Power brakes + dual masters? Any input?? |
Bill?
My idea too off? |
Russian Blue has this set of brakes on his '72, 3.6 using a Mercedes M/C. Not impressive as the bias was way too much up front. To the point of being dangerious. We added a bias valve which was easy enough to dial in.
930s are a cleaner solution imo. |
Where did you put the bias valve to cure too much front bias? Just curious |
The smart Racing setup is a bolt in for your car. I'm also curious as to where a bias valve would be put to cure front bias. 930 rotors are great, 930 calipers were great in their day, the same thing may be said of Big Reds shortly. |
Wrong term obviously.
What is the correct term? Proportioning valve? Back brakes locked up too soon under hard braking. |
Anyway, I'll have a set of GTP's on in a week. I'll let you know if the car stops. ;) |
My 930 set up went on without a hitch and worked very well from day one. No extra excitement involved. |
I need to run new lines anyway, should I run larger lines??
If so what size? |
