doozer's Avatar
Talking Brembo GTP's & Master Cylinder Ideas
Ok I am installing Brembo GTP's front and rear but someone said the Turbo Master Cylinder upgrade still was not enough for these brakes.
True or False?
I have the 84 boosted master setup and was going to go up to a turbo master but if this is not enough then maybe I could build a mount for the booster to push dual 25's.
Has anyone done this??
Any Input from the Brake guys??
Todd
I drank what? = Party out of bounds - PriceLESS - BudWIZER
"Boy Im gonna burn you a new one! - A new what officer?" = night in jail
993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Old 03-09-2005, 03:37 PM
Bill Verburg's Avatar
The 23.81mm boosted 930 unit will be ok, for sporting use most of us will prefera higher harder pedal which can be provided by a bigger m/c bore. Unfortunaely adapting the hyd. boosted 25.4 from a 993tt is non trivial.
The other alternative is a Smart Racing boosted dual master setup which can be had w/ twin x1" masters.
Bill Verburg
Old 03-09-2005, 04:06 PM
doozer's Avatar
So is it a straight swap on the 23.81 or do I need a bias valve?
Woo 35.4 993tt not trivial - sounds like my kind of fun
Todd
Old 03-09-2005, 04:17 PM
the 930 m/c is a straight swap, there are some wiring differences for the stoplight and warning switches on some cars, its a matter of 2 wire vs 1 wire hook up.
The preproduction #s supplied to me by Race Tech(Brembo) indicate an extreme front bias(another reason I didn't like them) the production versions currently being supplied may be better in this regard, I really do not know. Please check and let us know what pistons they are being shipped w/. A better evaluation of bias can be supplied at that time.
Bill Verburg
Old 03-09-2005, 04:29 PM
doozer's Avatar
Thanks Bill,
I will let you know what I find!!
Anyone want to buy a new 84 OEM Master??? I have one
Todd
Old 03-09-2005, 04:37 PM
Ran the GTP-LW with a 23 MC with no issues at Sebring. Pedal was high and hard...
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 03-09-2005, 04:38 PM
Ran the GTP-LW
different calipers, hey you were supposed to get back to us w/ some #S on that set up
Bill Verburg
Old 03-09-2005, 04:46 PM
doozer's Avatar
Thanks James!
Todd
Hey Bill, I'll get them in the next few weeks. Sorry about that but I have had a very steady stream of cars coming in for some major fabrication work and haven't had any time.
Cheers, James
Ayrton Senna
1993 964 RS
Old 03-09-2005, 04:52 PM
One last thing, if the GTPs are as front biased as the preliminary #s suggest, then a dual master setup will be very desirable.
Bill Verburg
Old 03-09-2005, 05:02 PM
doozer's Avatar
Ok back to that:
What about taking the 84 OEM booster, removing the OEM master , CNC'ing a dual master mounting system with ballance bar and having the booster drive the two masters?
Power brakes + dual masters?
Any input??
Todd
Old 03-09-2005, 05:23 PM
doozer's Avatar
Bill?
My idea too off?
Todd
Old 03-10-2005, 06:33 AM
rdane's Avatar
Russian Blue has this set of brakes on his '72, 3.6 using a Mercedes M/C. Not impressive as the bias was way too much up front. To the point of being dangerious. We added a bias valve which was easy enough to dial in.
930s are a cleaner solution imo.
Old 03-10-2005, 07:29 AM
Where did you put the bias valve to cure too much front bias?
Just curious
Old 03-10-2005, 09:22 AM
DUnno, guess it depends on your skill set.
The smart Racing setup is a bolt in for your car.
I'm also curious as to where a bias valve would be put to cure front bias.
930 rotors are great, 930 calipers were great in their day, the same thing may be said of Big Reds shortly.
Bill Verburg
Old 03-10-2005, 01:55 PM
rdane's Avatar
Wrong term obviously.
What is the correct term? Proportioning valve?
Back brakes locked up too soon under hard braking.
Old 03-10-2005, 02:52 PM
Moses's Avatar
Ain't that rear bias?
Anyway, I'll have a set of GTP's on in a week. I'll let you know if the car stops.
Old 03-10-2005, 02:58 PM
rdane's Avatar
Yep. Not sure what the new M/C had to do with it or the weight of the car...but it wasn't fun. Fixed now.
My 930 set up went on without a hitch and worked very well from day one. No extra excitement involved.
Old 03-10-2005, 03:14 PM
If the m/c is too small, combined w/ the small early lines means the rear will lock prematurely even w/ proper native bias.
Bill Verburg
Old 03-10-2005, 07:00 PM
doozer's Avatar
I need to run new lines anyway, should I run larger lines??
If so what size?
Todd
Old 03-11-2005, 07:44 AM
