Can anyone verify this statement as true?
"The 964 and 911 3.2 used the same Air Flow Meter." Thank you in advance, Paul
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
bumpitty
False
The design is similar in that they both use a mechanical flap to measure air flow
Thank you, Bill.
They are in fact the same part. The Porsche part number for the carrera is 930 606 123 00 is superceded by the 964 part # 964 606 050 00, they all have the same 0 280 203 023 Bosch part number. I have 3 AFM in my basement, two from a 964 and one from a 3.2 they are identical and can be interchanged.
Todd
1989 911 Targa |
same.
I don't know where you are getting your info but
964 606 050 00 is for 964 M64/01 - 03 930 606 123 00 is the 3.2Carrera part
the bosch catalog lists the same number for both. 0 986 280 026
the 930 number supercedes to the 964 number.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 03-12-2005 at 08:49 AM.. |
Carrera
964 If you say so
1989 911 Targa |
it's just upside down on the 3.6. the plug faces forward on the 3.6 and back on the 3.2.
I learn something new every day
me too. trying to remember it is the hard part.
