SLR
Oil breather hoses
I need to replace the 2 breather hoses from the front of the engine to the oil tank, Can this be dune with the motor still in the car? the car is 1986 Carrera.
thanks Steve. |
I could not get sufficient torque on the hose clamp at the breather cover to break it loose. I am sure have done this successfully but a partial engine drop would make this alot easier.
Walt 82SC 3.0 81SC 3.6 |
It is doable without an engine drop. You will probably need to remove air filter and the MAF sensor. Maybe even the left side fan to get more elbow room.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
