I don't know how it happened but my 5000 miles old Brembo cross drilled rotors on my Supra TT needs to be resurfaced,steering wheel shake on applying brakes ? My question is since they are pretty new would i be able to get them resurfaced at a machine shop or just throw them away and get another set ?
Feedback appreciated. Thanks |
They can be cut, but some shops will not do them.
All that's required is small cuts to reduce the cutting blade chatter as they pass over the holes. I have done the rotors on my 930 once myself. |
Instead of turning them on a lathe, disc rotors should have their surface ground down.
How exactly do you grind the surface ?
Ruf930, Good to know they can be resurfaced. Thanks |
Check this website http://www.landisgardner.com/whatsnew/art15.htm Last edited by ruf-porsche; 03-13-2005 at 08:42 PM.. |
if you believe the "rotors don't warp" theory, then it's just the accumulation of material on the pad.
