Meka's Avatar
Hard shift second
My 84 Carrera is hard shifting into second gear. What I mean is that I must pull back very hard on the stick. I'm going to replace all the shift bushings when I have the time but I have a feeling that not going to solve the problem. Any chance this is a common problem with this year 911? If it is how do I fix it? Thanks
Old 03-16-2005, 07:18 PM
911FL's Avatar
Have this problem as well. Do a search on this and you'll find quite a bit. I believe it's the second gear synchro and am waiting on a future tranny rebuid. In the meantime, if you shift slowly (one member said "one mississippi" works, and that's just about right) then the shift should improve. I tend to not think about it anymore since my body has adapted to the problem and most of the time it's pretty smooth. Bushings are never a bad idea. By the way, this is common to the 915 tranny that was used for a lng, long time so not just confined to the '84's. Hope this helps.
Dan
“Out on some Sonoma County road, with Jimmy Dean and Steve McQueen”
1984 Carrera Targa
Old 03-16-2005, 07:41 PM
PorscheGuy79's Avatar
Welcome to the club, the bushing helped a bit for myself.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 03-16-2005, 07:43 PM
Welcome to personality of the 915 Tranny! :-)
What you describe from 1st to 2nd is a common report.
Replacing the shift bushings (cup, shift rod , and coupler) will help. Also try Swepco 201 tranny fluid as it may help a little too.
For me, 1st to 2nd improved a little with the bushings, and Swepco helped more with 3rd through 5th shifts. Not night and day changes, but small subtle improvements.
Hope this helps!!
Quincy
Fountain Valley, CA
'83 SC, '13 P-GTS
"Air cooled, fountain pen guy, living in a water cooled, iPhone world"
Old 03-16-2005, 08:50 PM
Ultimate help is going to be a tranny rebuild.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-16-2005, 08:57 PM
GOT TURBO..
MobileWrks's Avatar
It is common.....
most of the time,1st and second go out first,have you pulled the drain plug to make sure the fluid has no metal?? Heres a suggestion,theres some stuff at kragen called "lucas" they have several different applications,fuel,rack,tranny etc..After your bushings and adjustment,try that stuff,it does help.. i used it on my old integra"yahyah..import i know" but it helped quite a bit,till i sold it..yah!!!
Old 03-16-2005, 09:03 PM
