Front wheel bearing rebuild
I just rebuilt my front wheel bearings and brakes . I noticed that there was no lock washer behind the allen headed lock nut. Is there a part missing ?
1986 blk 930 2000 expedition 2000 bmw 3 series convertable 1996 Silverton 312 sedan bridge |
I just checked a used one in a parts bin and didn't find a washer....
#30 is a thrust washer 911.341.663.00
O.K better pick when of them there thrust washers . So Bill itching for spring yet ?
You know it
one good side i'm able to get lots of running miles in.
Steven,
I have the parts to do this repair as well. How did yours go? Any advice? Thanks, Don
'93 BMW 325i |
It was very easy and very messy. Have lot's of paper towels for the old grease and some brake cleaner ready also make sure you have a long drift to punch out the old race's.
You do not have permissi
It's better to heat the hub and press the races in and out. Cooling the races shrinks them and helps them slide easier, it's in the archives.
Did this job last Sat. Oh, what fun! I had to have a shop press out the races.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
I believe I've read something about disconnecting the brake lines to move the calipers out of the way. Did you have to do this? I'm in Richmond, Va. anyone have a press or recomend where to take it to to have the races pressed in and out?
Thanks, Don
'93 BMW 325i |
You don't have to disconnect the brake line. Just make sure you get a coat hanger rigged up to support the caliper before you remove it and then have to go in the hosue find a coat hanger.
If you do remove the brake line then use a stick wedged between the seat and brake pedal to partially depress the pedal (Keep it this way until the line is reinstalled onto the caliper). This will prevent fluid from continuing to drip out of the open line.
I personally have always just removed the brake lines to remove the calipers. It really is not that difficult to reinstall and do a quick bleed. Good luck.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
Forgot to mention that you can also Dremel out a slot in the strut housing eyelet where the brake line feeds through. The clip will hold it in place and you can still move it around without having to open the brake line. I did this on my new Bilstein HD's before I installed them on my 993 to prevent having to open the brake line. Works like a charm.
Didn't that read like Steven was asking about a washer for part 32? That's how I took "behind." Sorry.
O.K. did a little research and looked at old outer bearing.....washer was stuck in the varnish/grease sorry . On the good note get my wheels back wednesday had the centers powder coated and purchased porsche centers painted to match ! On another note I have two real nice black 6 way adjustable porsche seats if anybody needs them. I am willing to barter or sell cheap to another P.P. who needs them,no e-bay sellers please.
1986 blk 930 2000 expedition 2000 bmw 3 series convertable 1996 Silverton 312 sedan bridge Last edited by steven polaski; 03-15-2005 at 04:56 PM.. |
