footwell blower squirrel cage on AC condeser motor shaft
I just put a old footwell blower motor cage, the plastic one, on a new bosch front AC condenser blower motor. seems to work well. But I wonder about volume compared to the metal squirrel cage of the original AC blower. It's just a bit smaller in diameter only, width is about the same. Fit's well in a spare housing I have. I was going to epoxy it on justto be sure. Shaft diameter is the same.
anybody got anything about volume?
Old 08-25-2005, 07:36 AM
Not that this really addresses your question but I think you may be ok since I get better cooling on my 88 with the fan at the #2 setting vs. 3. It actually warms up 5-7 degrees when I boost the fan speed. It seems the evaporator is a definite weak point since it does not seem able to remove heat very effectively with the higher air volume/speed. Makes me think an improved evaporator would be a good addition.
BTW, I was born in Lafayette...dad was in the "oil bidness" down there and has great memories of the Petroleum Club back in the day.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 08-25-2005, 02:48 PM
oil bidness, 401K, and $80 a barrel go well together
I believe you're speaking of the evap blower,(in the smuggler's box) I'm talking about the front condenser blower by the battery.
Old 08-25-2005, 03:30 PM
Sorry, wasn't paying enough attention. I really don't know how much impact that front fan makes...I'm sure it helps but it is still really a marginal system at best and that's one of the weaker points. I'd really like to see a substantial upgrade to the condensor itself...in addition to say, an underbelly condensor.
Buck
'88 Coupe, '87 Cab,
Old 08-25-2005, 09:05 PM
