What are most common metric sizes on P-cars
I have to buy some wrenches tonight. Specifically for the oil pipe banjo bolt on the 87 Carrera chain tensioner supply line. What size is this?
I'm a limited DIYourselfer. My work will encompass brakes, oil changes and valve adjustments. I have some tools but could use new ones. Yes, I have a Motive pressure bleeder, soon to be put to it's first use. Instead of listing various tools, how about listing common sizes encountered. I'm going to buy a 4-piece wrench set including 10, 12,13,14 mm or 7-piece which adds 15,17,19 mm. Will I encounter the last three sizes? Thanks for entertaining yet another tool related question.
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
Yes, 15, 17 and 19 are very common on a Porsche - you gotta have 'em.
8,10,13,15,17 for nuts and bolts
6mm, 8mm 17mm for allen keys Best to add another 13mm spanner that is has different length/ angle to the one you've got. You will always come across a nut you can't get to somwhere with just the one style of spanner.
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
Agree with those guys. The one I use most often is a 19mm deep socket for wheel lugs. You should get every version of these sizes - deep impact sockets, regular short sockets, offset wrenches, open end, hex sockets, hex keys and even a cheap set of ratcheting box wrenches. I think 13mm is probably the most common on a 911, followed my 10mm. You'll need a 24mm (I think) for the fan pulley and 36mm for some of the hard oil lines. Pretty sure 36mm is the biggest one on a Porsche.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
10mm and 13mm somehow work for 80% of all fasteners in all cars ( metric)....
Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
And I agree with Rick Lee - can't have enough different versions of the same size. 27MM for the steering wheel nut.
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
I would recommend buying a set package of tools to start with if you don't have a good start. Craftsman has sets that range in price from $50 to thousands. You can get a nice set in the $200 - 300 range that will save you both time and money in the long run. And there guaranteed for life. Look at the individual prices and you will see how cheap these sets are.
Example under $200: http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&fromAuto=YES&bidsite=CRAFT&pid=00933246000
68 911L |
I agree with 8, through 19 being the most popular. Some reason I find that size 8's are always in the worst spots. I would recommend one of those closed end 8mm wrench with an internal ratchet as a must have though I don't have one but do dream of one someday.
Neil '73 911S targa |
Virginia Rocks!
The more tools you have the more stuff you'll want to do. I have a whole set of Craftsman wrenchs running fromo 7mm to 18mm. I had to add a 19mm for the fuel filter. I have a stubby set as well. And an offset set of 5 from 8mm 17mm and a set of nice ratcheting ones from 8mm to 18mm (skips a couple).
Then there's all the other fun stuff, sockets, extensions, wobble extensions, 3 torque wrenchs, etc etc. Buy good tools and they will last a lifetime. I buy stuff and then find a use for it. I found a set of 3 cheapo tin snips. Now I need to make something with that!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
RETIRED
don't forget, 27 and 30mm
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
This thread reminds me of an interesting concept I heard about once. Most designers try to design everything so that it is "just right". The extreme case is a design that it is 100% custom because the designer chose not to use any off-the-shelf components. An interesting alternative is when some designers design things they make a concious effort to minimize the number of part numbers in the design to simplify manufacturability. I thought that it was an interesting concept until I started to work on the Mazda 323 that I used to race. I almost never had to use an even sized wrench if my memory is correct. Just about every nut used the was either 7, 9, 11, 13, 15mm and so on.
A very clever idea.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
36mm axle and flywheel nuts and a 17mm allen....ahh bugs.
Scott 1982 911 SC 1962 sunroof bug 1991 WE Vanagon CARAT WRX conversion |
Formerly bb80sc
Cannot remember, is the shock bolt a 22mm or 27mm........
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
Presumably you'll get sockets too? Working with just wrenches is a pain, IMO. When/if you do, I find that a stubby ratchet comes in very handy more often than one would think. I never had any use for one until I got a 911.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
I'll want some kind of torque wrench for the valve cover nuts; any suggestions in terms of the size of the tool? I suspect I'll want something small to get into tight spaces. What is the torque spec for those nuts?
MBruns for President
Brakes? get a set of metric flare wrenches... And if you have a complete tool pouch - note the sizes of the wrenches in there and make sure you have corresponding sockets...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I also got a set of cheap harbor freight sockets so if I have to cut one up - I'm not going to cry about it... and make sure you have a long handle 17mm wrench...
I wouldn't bother to torque the valve cover nuts - as long as your wrist is not "iron" you don't need it.
You SHOULD use a torque wrench on the wheel lug nuts - a 1/2" drive type is the right size - search to get opinions on type & brand. Anticipate what else you'll do on critical fasteners... engine rebuild? brakes?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
