Aluminum deck lid
How rare is an aluminum deck lid and how should I go about stripping the old paint off to restore it?
Should I use it or is it too rare? Should it become wall art?
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
I would rather be driving
Where do you find this stuff?
![]() they were not super rare. I would use a chemical stripper. followed by a scotchbrite pad with very little pressure. If its in good condition, just scuff the paint and shoot over it. the work well as long as you don't push down to close the decklid.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Use it...
Famous last words.. "Hold my beer and watch this...' " The reason the Irish are always fightin one another is that there are no other worthy opponents ". |
I'll ask my restorer how he stripped mine. He did have a hell of time filling and sanding out the small dimples in it.
Neil '73 911S targa |
Go light, go fiber glass...sell the aluminum
I'd keep the AL lid one way or the other. I'd probably save it and keep it for a conv piece, and use F/g instead.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
These lids are great! They deserve to be used even if they take a few bumps.
I went from this: ![]() via this: ![]() To this: ![]() |
how much do those Al lids weigh?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I'll weigh it tomorrow when I take it off and let you know...
Yeah, Al lids are dead sexy. They make me randy baby, yeah!
Double Trouble
They are aweful. You will hate it....send it to me I will spare you the pain.
Nice find!
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
Lid Weights
Stock 65/68 Metal 14.7 lbs. (latch, no grille)
Fiberglass Ducktail on steel frame 13.3 lbs. (no latch or grille) Aluminum 5 lbs. (no latch or grille) Does someone have the all fiberglass weight. And, the later all metal lid without the early center bar? Bob Last edited by Fleming; 03-18-2005 at 07:14 AM.. |
Thanks!
And - Steve - I am already Randy...
Here is what I had in my wt. database on these items:
stock steel engine lid w/metal gril, no hinges 15.8 fiberglass engine lid, Rennspeed 4.0 Bob - what kind of scale did you use for these items? a bath scale? postal scale?
There is another part to this story.
The 911s that had the alu deck lid also had an alu license plate panel. I made sure those cars also had alu hardware and bracket for the alu Colorado license plate. These may also have been the cars with the OE lightweight mufflers. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Just another thought for this thread....the license panel in aluminum was repro'd, unfortunately not the deck lid....
eric |
Yes, and here are the data (note: not strictly comparable):
R. steel center panel, w/ license plate and bracket 5.3 Al center panel, no license plate or bracket 1.8 wt is in lbs.
Randy my measurments were on a grams scale.
I converted down to pounds. The raw numbers are Steel=5480 gr. Fiberglass on Steel=4985 gr. and Alum=1895. The repro alum license panel is junk, the bumper openings vary over 1/2" from side to side and take a ton of reworking to level. The lower bracket spot welds pop off. Grady, Aluminum hinges, stock shape or 911R style? Bob |
Bob,
I have seen aluminum, stock appearing, hinges on some race cars back then. Not 911R style. You had to use a hood prop because there weren’t any lifts. Best, Grady
Thanks Grady. Now I have another item to look for.....mmmm light is good.
Bob |
