Unhappy Engine won't start
once in a while my 3.2 won't start. replaced relay under driver seat. seams like it's electrical.
as always thanks you all are great.
steve
97 boxster
88 carrera
83 crossle
125 shifter kart
truck
Old 03-19-2005, 08:42 PM
Semper drive!
rcecale's Avatar
Can you give us more details?
When you say "won't start", do you mean it turns over but will not fire up? Or, like a situation I just fixed, all the electrical comes on but the engine will not even turn over.
In my case it ended up being a bad starter solenoid, so I replaced the entire starter/solenoid assembly. It turns over and starts quickly, whenever I turn the key now.
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 03-19-2005, 09:04 PM
Sometime my 87 craking fine but not fire, some time the car just die in the middle of the road. I so tired with the problem and have the shop check out, they said the ECU is defect and the new box is $1400
I took out the box, clean the ECU connectors and resolder all the solder joins, and the problem seem go way, and car running fine ever since
Don't know is the same problem as you car , but give it' worth a try.
911 1987 Triple Black Cab Turbo Look >> weekend car
SPF MK III Shelby Cobra 427 550HP >> thrill for speed
BMW 88 635CSi daily drive
BMW 87 325i use for rainning day (donation)
Benz 06 E350 use for pick-up kid on car pool day
Old 03-19-2005, 09:33 PM
eddiehotrod's Avatar
Reference sensors. Check them then check the gap.
Old 03-20-2005, 11:15 AM
